Old 3rd November 2009, 01:36 AM   #1
Default Ideal suppliers and Shorting
an ideal voltage source has an internal resistance of zero. this means that it can deliver any current while its voltage is not affected, right? If so then what will happen if I put a zero resistor to its terminals or short its terminals?
If I put a voltmeter across a such supplier then what what do I''ll read when I short the supplier?
THANKS
Electronman is online now
Old 3rd November 2009, 02:26 AM   #2
You will still read the correct output voltage.
The current will be infinite.
Not just thousands of millions of amps but truly INFINITE.
Warpspeed is offline
Old 3rd November 2009, 02:31 AM   #3
An ideal voltage source is just that, mathematically ideal, none such can exist in the real world.
straight answer, har har."
Sceadwian is offline
Old 3rd November 2009, 02:36 AM   #4
The circuit theory says that you can't short circuit an ideal voltage current, because as you said its internal resistance is "0". And you can not either left in open circuit an ideal current source because its internal resistance is infinite.
"A person who never made a mistake never tried anything new"
Albert Einstein
Karkas is offline
Old 3rd November 2009, 02:51 AM   #5
Thanks for all inputs.
Can somebody explain it mathmatecaly to me? When you short a voltage source then how does it feeds another load which is parallel to that shorted pin??!
Old 3rd November 2009, 02:58 AM   #6
If you make the calculus you will have an infinite current, and that mathematically is right, but the circuit theory says that you can't short circuit that source.
It couldn't, because no current will flow through a load that is bigger than "0" when there's a short circuit.
is there any disagreement or confusion?
Albert Einstein
Karkas is offline
Old 3rd November 2009, 03:33 AM   #7
It can feed as many additional loads that you have, at full voltage too.
Simply because the current source is infinite, so it can never be overloaded.
Old 3rd November 2009, 04:00 AM   #8
But I Can not understand it Mathematically?!
Old 3rd November 2009, 04:16 AM   #9
Infinity is so very large, is beyond understanding.
That is the whole point.
Old 3rd November 2009, 09:40 AM   #10
If you short a non-ideal voltage source then it will NOT power a load parallel to the short.
A rectangular bear is just a polar bear after a coordinate transform. -- I dunno who.
A recent study shows that research causes cancer in rats. -- I dunno who said that one either.
Noggin is offline
Old 3rd November 2009, 09:51 AM   #11
I am talking about an IDEAL one!
Old 3rd November 2009, 10:00 AM   #12
Yup, an IDEAL voltage source, with infinitely more power than all the Galaxies in the cosmos combined.
Old 4th November 2009, 02:47 AM   #13
Voltage source - Wikipedia, the free encyclopedia
What don't you understand?
ideal, shorting, suppliers
GLCD any one that used one have a ideal what this is be80be Micro Controllers 2 2nd July 2009 03:20 AM
Capacitor Shorting freeskier89 General Electronics Chat 28 21st November 2005 08:29 PM
Shorting an AC signal to ground evandude General Electronics Chat 10 12th October 2005 01:19 AM
Ideal Diode. lord loh. General Electronics Chat 12 2nd June 2005 06:16 AM
opamp shorting rohini_123 Electronic Projects Design/Ideas/Reviews 0 31st January 2005 09:28 AM
