Old 2nd November 2009, 11:40 AM   #1
Default Aluminum Capacitor
I bought some of these for my BuckPlus 7023 LED drivers. The data sheet says I should wire them in next ot the buck if the DC power is more than 18 inches away.
The housing seems metal which I didn't really think about when I purchased them. Does that mean it's grounded to the housing? My LEDs aren't but I know a lot of LEDs are grounded to the thermal solder points in the base. Anyway, I wanted to mount them upside down on this heatsink I'm using to mount the LEDs and I don't want to risk electrocuting myself. So, does anyone know if the device is grounded to the casing?
thepaan is offline
Old 2nd November 2009, 12:22 PM   #2
I don't think so, but just use an Ohm meter to check.
But more importantly, don't mount electrolytic capacitors on the heat sink. Heat is the killer of electrolytics.
Ken
KMoffett is offline
Old 2nd November 2009, 02:40 PM   #3
Wait, what? How is mounting on a heatsink going to make it hot? If anything it should make it colder, right? I couldn't exactly figure out how the calculation for heat transfer should work over a surface area but it's a pretty huge heatsink. That would be the U81C for the 2U system.
But, good call on the ohm meter. I'll take one to work tomorrow to check.
thepaan is offline
Old 2nd November 2009, 02:54 PM   #4
Heat sinks get hotter than the ambient temperature. They transfer the heat from the source to the air through the metal. Sticking your caps on the metal means that they will pick up heat above ambient. Just not a good idea.
Ken
KMoffett is offline
Old 2nd November 2009, 03:20 PM   #5
Aren't they already going to be hotter than ambient due to the electrical current being applied?
thepaan is offline
Old 2nd November 2009, 05:58 PM   #6
An ideal capacitor does not dissipate energy, only stores it. Practical capacitors don't get warm unless they are used in high frequency, high ripple current applications such as the output caps on switching regulators. In that case the heat is cased by the ripple currents throught the small parasitic capacitor series resistance (ESR).
Carl
Curmudgeon Elektroniker
crutschow is offline
aluminum, capacitor
vaporize aluminum wire George L. General Electronics Chat 5 11th September 2009 05:01 AM
how to hand solder smd aluminum electrolitic capacitor? arhi General Electronics Chat 10 7th April 2009 09:06 PM
Supplier of millable aluminum? Marks256 Chit-Chat 19 7th July 2008 05:11 AM
calc Tr of aluminum object? justDIY General Electronics Chat 2 9th January 2008 08:40 PM
Need Help etching Aluminum TheDesignShop Electronic Projects Design/Ideas/Reviews 4 28th April 2004 03:48 PM
