I've looked and looked to find something to power a portable usb drive in my vehicle. My stereo powers a flash drive but wont a portable drive. I bought a lighter style adapter--it worked for a couple months an the output changed just enough it creats a power error. The drives AC adapter takes it down to 5v 2 amps DC. While it was working-- it was pretty awesome, 160 gigs of music. I hooked up a power inverter to power the AC adapter but thats a pain in the neck,, really bad when you forget to unplug it(the battery is dead) Anyone know of a device or a way to make a little curcuit board to do what I need? Cant believe its something I couldnt find on the web. Seems like it should be easy OR Im not asking the correct thing. | |
You should be able to simply use a 5V regulator such as the NTE1934 which regulates up to a 30 DcV input to a 4.9-5.1 DcV output with a current up to 2A.
You might consider a 1N4734 5.6V zener after the regulator to protect your devices from overvoltage and be sure to add a fuse.
Many cellphone 'cigarette lighter' chargers put out 5vdc. Avoid Motorola they are not. Samsung are 5 vdc. Two amps might be a challenge. Go for 3G phone charger which is more likely to put out up to 2 amps. Probably cheapest and fastest solution. Last edited by RCinFLA; 2nd November 2009 at 04:23 AM. | |
I give these a try and post results]Thanks.
| | #6 |
for 5v from 12v you can go for voltage regulator(7805 ic) & then using buffers you can achieve desired current magnitude.
| 12v, amp |
| Need 6V & 12v Battery Charger | amdkicksass | Electronic Projects Design/Ideas/Reviews | 16 | 6th August 2009 11:57 PM |
| [Question]0 -12V supply for op amp | yes123 | General Electronics Chat | 20 | 9th June 2009 02:25 AM |
| Batter Charger AGM 12V 4 Amp/hr | voodoo5293 | Electronic Projects Design/Ideas/Reviews | 9 | 18th May 2009 03:15 PM |
| Battery backed up 12v & 5v supply | oliverb | Electronic Projects Design/Ideas/Reviews | 26 | 4th December 2008 12:40 PM |
| 12v power amp | truenoteno | Electronic Projects Design/Ideas/Reviews | 3 | 21st November 2003 06:46 AM |
