Old 1st November 2009, 10:59 PM   #1
Default repairing flash drive. is it possible?
hello to all. i have a 2gb flash drive (Silicon Power) i think its has burned. i have another one that are the same as the first. can i remove the flash ic from the first one and put it to second one and have a 4gb flash drive? ther is a place for it in the back of the board of the flash drive. is it possible?
younes_ysf is offline
Old 2nd November 2009, 12:34 AM   #2
There won't be any benefit paralleling two flash EPROM chips. Using the same addressing you get double data in the stick.
Boncuk is online now
Old 2nd November 2009, 01:56 PM   #3
Post some pictures. it MIGHT be possible or you might wreck the good drive...
If the good drive has a space to solder another IC if might be an option, ie the same PCB is used when they make 2Gb and 4Gb drives. There is sometimes a jumper you connect to activate the second chip.
Mr RB is online now
Old 2nd November 2009, 02:03 PM   #4
Doubtful.
Mr RB was correct in suggesting about the PCB's used...since the only real difference between 2 and 4GB would be the extra address line its quite possible (if they are from the same manufacturer) that the PCB's are the same, just with different parts.
Careful desoldering the SMT flash chip on the replacement part (the one where the new flash chip is going into) you do'nt want to break the pads. Generally either the part or PCB has to be sacrificied, that is to say, if the part is dead you can cut it out leaving the PCB 'ok', if the PCB is dead and you need the part, you can wreck the pads just getting it off in one piece.
In fairness, these things are so cheap now days, might just be an idea to buy a new one I mean, 4GBflash drives are about $5 these days.
Inconsistency is the key to flexibility!
Blueteeth is offline
Old 2nd November 2009, 02:05 PM   #5
2G USB drives are selling for pocket change thesedays.
Bill
Smart Kits build Smart People
drive, flash, repairing
USB to USB flash Drive File Copier emildownloads Micro Controllers 5 6th December 2008 07:15 PM
Tired of loosing my flash drive. 3v0 General Electronics Chat 9 15th February 2008 03:01 AM
3.5” Hard Drive Physical Size, True 3.5” drive? stevef22 Datasheet/Parts Requests 4 14th September 2007 03:49 AM
How can I fix my flash drive? andales General Electronics Chat 7 8th December 2006 05:03 PM
Converting Normal pc cd rom drive to dvd drive litto43ph Electronic Projects Design/Ideas/Reviews 8 29th January 2006 08:09 PM
