Old 31st October 2009, 08:24 AM   #1
Default zener reverse vltg
can anybody tell me how to obtain a higher reverse blocking capacity from lower PIV zener ........
bublee is offline
Old 31st October 2009, 12:25 PM   #2
Add zeners in series
colin55 is online now
Old 31st October 2009, 12:41 PM   #3
thanx for the reply
bublee is offline
Old 31st October 2009, 04:44 PM   #4
since we're on the topic of zeners... see this circuit:
http://www.electro-tech-online.com/a...rum-preamp.png
This circuit is proposed by audioguru for my disdrometer project
Acoustic Disdrometer
How does that zener clamp the output from a Piezo transducer?
-The kinda guy who would improvise so much that you'd say "Here's 50 bucks for your Gigantron"
http://vortexelectricaz.blogspot.com
Vizier87 is offline
Old 31st October 2009, 05:42 PM   #5
I was wrong.
The BAT85 is a Schottky diode, not a zener diode.
It conducts when the input goes negative by only 0.2V to avoid destruction of the input of the opamp that has a max allowed negative voltage of -0.3V.
audioguru is offline
Old 1st November 2009, 02:20 PM   #6
okay.... so a Schottky diode it is.. can it be replaced by the IN- series? Like the IN4148 or IN4001?
Vizier87 is offline
Old 1st November 2009, 02:55 PM   #7
The Schottky diode has the required 0.2V to 0.3V forward voltage to stop the negative input to the opamp from exceeding its max allowed negative voltage of -0.3V.
An ordinary diode has a forward voltage of 0.6V to 0.7V so the input of the opamp will be damaged.
Old 1st November 2009, 03:02 PM   #8
1N400X series are general purpose diodes for AC-to-DC applictions. 1N4148 is a fast switching diode. schottky diodes are little bit different from these, because of their low forward voltage drop leading to lower levels of power loss compared to ordinary P-N junction diodes. schottky diodes are also known as surface barrier,hot carrier, or even hot electron diode. they are widely used in radio frequencies as mixer or detector,and in power applications as rectifiers where low forward voltage drop is required.
You can try google for different types of diodes or even wikipedia can help.
yafch is offline
reverse, vltg, zener
Zener before optocoupler loup-garou General Electronics Chat 2 16th February 2009 12:46 AM
zener diode 1963 General Electronics Chat 2 5th October 2008 01:57 AM
Using a 5.1V Zener as a regulator ? iso9001 General Electronics Chat 5 7th December 2004 02:24 AM
Zener diode Vinit_dhulla General Electronics Chat 1 15th April 2004 10:16 PM
Zener Diode P\N ? Clinton General Electronics Chat 2 19th January 2004 02:15 AM
