Old 30th October 2009, 04:08 AM   #16
Hmm. Silicon oil?
I think I still have a gallon or two of that around anyway. If not I know where I can get it cheap! (and legal)
Any idea what capacitance something the size of a 5 gallon bucket would have at 250 volts or less?
What type of insulator material do they use thats not hard to find?
I can get many different plastics and types of paper easily enough.
I can get the poly sheet stuff like sceadwain mentioned. But I have seen many capacitors that have different types of paper like material saturated with oil in them as well.
"Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
"Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
"Your impossibility may just be my day to day routine." -- tcmtech
tcmtech is offline
Old 30th October 2009, 11:38 PM   #17
I would think you're missing a really big section there Boncuk =)
I would say a cap is generally in the range of nf to maybe 100u
I would say a large cap is generally 100u to 10000u
very large to super cap would be up to the 1F range to perhaps 50F. Anything larger than that I would call a large supercap, or an ultracap. There really is no set range or language definition. But think you're short changing what should be called a super cap because it's not so much about the farrad rating of hte cap but the overall energy density. I have 1F 5V supercaps that are smaller than 6 volts 10,000u caps.
straight answer, har har."
Sceadwian is online now
Old 30th October 2009, 11:57 PM   #18
"As far as super caps go the only thing that makes them different is the surface area per unit volume. You can make a 'super cap' out of 'normal' materials... you just gotta make it bigger =)"
-> So you dont think theres a difference in technology then between Panasonic which are "organic" supercaps and Cooper which are "aerogel" supercaps.
OK I'm talking about 50 - 100 F range, you dont seem to consider that as "supercaps"
About voltage ratings, pay strict attention to them. For my application I need 3V, so that would be 2 x 2.3 V rated capacitors in series. That halves the capacitance, doubles the ESR value. AND you have to pay strict attention to balancing: what would happen if one cap in series is at one extreme of the cap rating, say +20%, and the other is -20%, would they still be within tolerable limits then...
WIMA seems to make interesting products, too bad the voltage rating is always so low...
tadam is offline
Old 31st October 2009, 01:25 AM   #19
I suppose a voltage rating of 14 is sufficient for many applications unless you want to use them with a 24V truck battery.
If you want higher capacitance you might connect them in parallel.
Boncuk is online now
capacitors, super, world
Around the world uaefame Robotics Chat 5 25th September 2008 10:08 PM
Super capacitors Overclocked General Electronics Chat 12 7th October 2007 05:50 AM
Super super noob question hvgap General Electronics Chat 10 14th January 2007 12:12 AM
Super capacitors ym2k General Electronics Chat 12 18th August 2006 12:53 PM
RC plane around the world :) bloody-orc Electronic Projects Design/Ideas/Reviews 5 11th September 2004 06:24 AM
