Hi I'm looking at a CB transmitter and it states that it can deliver 4W into a 50ohm load while running from a 13.5V supply. It is a one transistor amplifier and there are no internally generated voltage sources, so the 13.5V is all there is. If you do the maths it appears that you need a 39.9V peak to peak sinewave across the 50ohm load to cause it to dissipate 4W. Where does that voltage come from?? I'm guessing that there is a resonant circuit but does anyone know the correct answer? I've seen other amps promising up to 200W, surely the Q needed there would be very difficult to achieve? Or is my maths just completely wrong? Many Thanks James | |
Yes you are right. The voltage is changed using a passive LC (inductor-capacitor) circuit between the output transistor and the 50 ohm load. This is called a matching circuit and is commonly used in RF amplifiers. You can estimate the actual impedance that this circuit presents to the transistor, possibly something around one half an ohm which theoretically might allow it to generate about 8 watts if all was ideal, but I guessed that the transistor would only be 50% efficient at its job.
__________________ RadioRon | |
Thanks Ron I'll go home tonight and do some research - because now, what I would have considered as a simple 'filter' circuit before has gained a life of its own and become almost active. An initial question that occurs is that there is no damping resistor in the circuit I have so how do they control the Q and hence the output voltage and power? In a production environment I would have thought this important. Cheers James | |
Be aware that some CB radio manufacturers, the ones geared toward the illegal market, are not filtering their poorly biased cr@p radios.
Phew - the maths is daunting - the stuff I've read about matching circuits is very deep - I'm sure that the output voltage is tied up with a dB figure somewhere..... Anyone got a link to a site with a more gentle description of how the thing works? I know this amplifier is the class where the conduction is less than 180 degrees, this is effectively a pulse output - I am guessing that it is a pulse that hits the tuned matching circuit and makes it resonate by hitting it at the right PRF. To my mind thats not really an amplifier as such, more a larger hammer than the last stage! ke5frf - I don't have the amplifier - just the circuit and an on-going discussion at work. The radio spectrum is safe! James | |
| | #6 |
| We may have to see the schematic to comment much further.
| | #7 |
Hi Ron Attached are the circuit and parts lists - I've worked out the inductance values, well, ish simply from the physical size and some formulas - so exact values are suspicious but near. (Don't have them with me at the moment) L4 with C6 and C7 resonate around 27MHz, what I assume is a Pi filter L2 and C3 C4 and C5 is around 23 MHz (possibly should be higher than 27MHz in practice?>, L3 has a reactance of around 60 ohms. All seem about right. While I can sort of guess which each bit does I still can't see how you can work out the output voltage/power and what controls it. Not sure what the diode pairings are all about either. Any input gratefully received! James | |
| | #8 |
General observations first. You called it a transmitter, I call it an add-on amplifier. A transmitter is usually a more complete combination of modulator and amplifier. But I'm nit-picking. On my initial look, the receive path is switched through S1 but I don't see anything to drive S1, so perhaps it is just a manual bypass switch? Alternatively, the path through L1, C2 and C9 may be the receive path. Clearly the diodes are there to perform a crude form of rx/tx switching. For analysis, assume that rx signal voltages are too low to bias the diodes, whereas tx signals always are large enough to bias the diodes. Bad design is shown by allowing the bias voltage through R1 to appear on the output antenna connector when S1 is in bypass. Then again, maybe this is intentional to provide bias to something further up the antenna line? I also believe it is bad design to couple back to back rectifiers to an output network to any degree as these will generate harmonics and harmonics should be avoided near the antenna terminal. One way to conveniently analyze the design approach is to understand the mosts common design procedure for matching circuits such as these, and that is using the Smith Chart. You can find many online references to how to use this tool. Analysis of the LC networks may start by assuming that they are trying to make the S22 of this system as low as possible in a 50 ohm system. In other words, perhaps you can assume that the matched impedance at ANT is 50 ohms. Using a Smith chart, you can work backwards through C6+C7, then L4 then L3 to arrive at a possible output Z for the transistor. Same sort of procedure can be used for the input network, only in the opposite direction (on a smith chart, direction is important). Again, I caution that looking at a matching network as some sort of filter can be misleading as we are not so much interested in resonances as we are in the ability of each reactance to shift the impedance. Make no mistake, ultimately the matching network does perform some filtering as well, but that is not its main purpose. It is an impedance shifting network first and foremost.
__________________ RadioRon Last edited by RadioRon; 29th October 2009 at 06:33 PM. | |
| | #9 | |
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | ||
| | #10 |
| Power = voltage squared divided by impedance. So, if you had a much lower impedance (like maybe 1 ohm) presented to the transistors collector, you could generate 4 watts of power at that point? Yes you could. Then it is just a matter of using reactive components to trade voltage for current and vise versa. That is what the output matching network does.
| | #11 | |
Vpk = root(2) VRMS and Vpk-pk is 2 x Vpk thus Vpk-pk is 2 * root 2 * 14.4 = 40 odd volts (pk-pk) That's a lot of volts, a normal amplifier would need a 40V supply to produce that as Class A. Even more as rail to rail would be unlikely. James | ||
| | #12 |
I've looked at Smith Charts etc - and I have a long way to go in learning the whole theory. I can understand that you need to match impedances to transfer max power and that you don't want to reflect power back into the transmitter. But none of the stuff I have seen there leads to prediction of the voltage, it's all dB, impedance, etc. Impedance matching doesn't suggest voltages nor filtering or dB values. I'll have to keep on looking - I guess I need the Dummys explanation! James | |
| | #13 | |
__________________ RadioRon | ||
| | #14 |
I was always under the impression that transmitter power was not watts output at the antenna but the DC power (DC amps times DC volts) into the final amplifier. At least that's the way it is with amateur radio. You guy sure that you're not applying your math skills to the wrong set of parameters?
| | #15 |
Amateur radio practices are not necessarily the same as mainstream commercial practices. In the world of two-way radios, cellphones, wireless gadgets of all sorts, military radio, and just about everything else except perhaps high power broadcasting (not sure what they do), transmitter power is defined by the output power fed to a specified load resistance and measured with a watt meter. I think perhaps the measurement of DC input is a hold-over from the days when it was hard to measure RF output, but easy to measure DC input. The knowledge that the efficiency of converting the DC into RF could not exceed 100% puts an upper limit on the RF output even if you are only measuring the DC input, so its not a bad method for those without fancy test gear.
| radio, transmitters, voltage |
| Using LDO to clamp voltage for radio module | perky | General Electronics Chat | 6 | 12th August 2009 06:50 PM |
| FM Transmitters | codenose | General Electronics Chat | 2 | 9th March 2009 02:08 PM |
| Fm Transmitters | tonyt | General Electronics Chat | 6 | 13th September 2008 03:48 PM |
| Transmitters and Beepers | Carl Atkinson | Electronic Projects Design/Ideas/Reviews | 2 | 30th November 2004 03:40 AM |
| Transmitters!(With Pics) | Rf_Head | General Electronics Chat | 2 | 23rd August 2003 10:18 AM |
