| | #16 |
Thank you!
| | #17 |
Hey. Why is diode-connected MOS/BJT is used in a current mirror? Even when using a MOS/BJT as a voltage source, its diode-connected. I dont see why. Thank you. | |
| | #18 |
The diode connected transistor acts as a current sinc, and the current is determined by the series resistor. Since resistors can be made to tight tolerances, the current thru the diode connected transistor is tightly controlled. Also, the other half of the pair is a transistor that who's collector current/base-emitter voltage relationship matches the diode connected one, and since the base-emitter voltages are equal in both transistors, the output current is equal, and determined by the series resistor.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
| | #19 |
I understand what you said. You basically described how a current mirror works. But it could have worked just the same without the diode connected configuration (without connecting D/C to G/B), couldnt it? Last edited by alphacat; 30th October 2009 at 02:05 PM. | |
| | #20 |
Um, no becasue without this connection, the current would not be determined by the resistor. If the connection were not made, you would need a whole other bias arrangement to get any current. Now, you could probably find another bias that works, and would by perfectly legitimate. This is just the bias the current mirror uses. It's simple and effective. PS: I edtied my post, and I know you're online. You might want to re-read before responding.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. Last edited by BrownOut; 30th October 2009 at 02:12 PM. | |
| | #21 |
Oh, i see now. Thank you very much | |
| | #22 |
Everything you need to know about current sources and mirrors: http://focus.ti.com/lit/an/sboa046/sboa046.pdf
__________________ Natural laws have no pity.' -Robert Heinlein | |
| | #23 |
Hey guys, I got back to the lab and I wanted to see if i indeed built a 18-19mA current source. So Instead of 150ohm load (R2), I connected a 75ohm load (R2), and the current I got was IDS2 = 26.5mA. Do you have any idea whats wrong here? I think that Q2 might not be saturated (I measured VGS = 2.2V), i'll check its VTN and post it up here. Last edited by alphacat; 1st November 2009 at 09:29 AM. | |
| | #24 |
According to the datasheet of the BSS670S2L L6327, VTn is 1.2V-2V. The VGS in the circuit is 2.2V For R2 = 150ohm (18.7mA), VDS = 1.89V > VGS - VTn. For R2 = 75ohm (26.5mA), VDS = 2.7V > VGS - VTn. I dont understand why I got two different currents for two different loads Last edited by alphacat; 1st November 2009 at 09:29 AM. | |
| | #25 |
I don't know either. It looks like it should have worked.
| | #26 |
Yes its strange. I conducted the experiment again here are the results: R1 = 100ohm, IR1 = 26.85mA, ***VCC = 5V. VGS = 2.3V Each time I used another load: R2 = 150ohm, IDS2 = 20.5mA, VDS2 = 1.99V. R2 = 75ohm, IDS2 = 27.6mA, VDS2 = 2.92V. R2 = 25ohm, IDS2 = 38.9mA, VDS2 = 4.02V. I really dont understand whats wrong here. -- Edit: I added an important detail that VCC = 5V. Last edited by alphacat; 1st November 2009 at 05:59 PM. | |
| | #27 |
R2 = 150 ohm; (4.7 - 1.99)/150 = 18mA R2 = 75 ohm; (4.7 - 2.92)/75 = 23mA R2 = 25 ohm; (4.7 - 4.02)/25 = 27mA The current is tighter than you think. Have you thermally coupled T1 and T2? If not, then do so.
| | #28 | |
I changed VCC from 4.7V to 5V. Again, sorry, I thought only to give you these details. Anyways, this is the only difference (the VCC). About thermally coupling Q1 and Q2, I only soldered them as close as i could get. The gates are touching each other, but the drains are 1cm away from each other. The sources are 0.5cm away from each other. | ||
| | #29 |
It is critical in current mirrors that the transistors be in thermal contact. Otherwise, the output won't track the diode connected transistor's current.
| | #30 |
Oh I see. Do you think that its that crucial? (an error of 38.9mA/26.8mA * 100 = 145%). How do you thermally couple the transistors please? Thank you for your help and guiding. | |
| current, mirror |
| Problem with a current mirror | PGrogan | General Electronics Chat | 15 | 28th January 2009 04:52 AM |
| nmos current mirror with differential pair | leo47 | General Electronics Chat | 6 | 5th June 2006 09:17 PM |
| current mirror BJT or CMos | shermaine | General Electronics Chat | 1 | 19th November 2005 08:30 AM |
| Will current Mirror circuit deliver constant current to LED? | Haru | General Electronics Chat | 10 | 14th April 2005 11:07 AM |
| Mosfet Current mirror, but??? | Terrano | General Electronics Chat | 9 | 6th April 2005 09:31 AM |
