Old 27th October 2009, 05:17 PM   #1
Default High Side vs Low Side Mosfet Drivers?
Hello All,
This is my first post to this forum...
Could someone explain the benifits and drawbacks of using either high side / low side mosfet drivers?
In the past I have used lowside drivers such as the ir2121 / ir ir2120 connected to pulse issolators ( Ferite corred) to drive mosfets in a half bridge and H-bridge design.
I was looking at the ir2184 highside driver as an alternative so I could do away with the pulse issolators.
Could someone please explain the benifits / drawbacks and issues of using the highside method as opposed to the lowside method?
Kind Regards,
SRG
paragon37 is offline
Old 27th October 2009, 05:27 PM   #2
High-side drivers are meant to run with a floating ground. Low side drivers make the assumption that VSS is ground.
You should use the correct driver for the correct application. It's not a matter of advantages or disadvantages, but using the proper chip for the proper application.
smanches is offline
Old 28th October 2009, 01:51 AM   #3
Thank you for your reply!
Could someone please highlight in what applications one would select one method over the other?
Kind Regards,
SRG
Old 28th October 2009, 01:58 AM   #4
As smanches already said, you do not get to choose whether to use a high-side or low-side gate because you do not get to choose whether you get to use a low or high side MOSFET. If you are forced to use a low-side MOSFET, you use a low-side gate driver. If you are forced to use a high-side MOSFET, you use a high-side gate driver. Simple as that.
dknguyen is offline
Old 28th October 2009, 03:23 AM   #5
A high side driver is a boot-strapped supply driver of an output N-ch MOSFET with a level shifter on the driver's input.
One typical useage is for an H-bridge MOSFET output driver. It could also be a simple push-pull output MOSFET output (half an H-bridge).
When the bottom output N-ch MOSFET is 'ON' it also charges a capacitor that become the high side driver power supply when bottom N-ch releases and upper (highside) N-channel MOSFET conducts. The capacitor is 'boot-strapped' up in the air (to higher voltage) to become the supply for the high side gate drive. There is an external diode to the regular supply that is connected to this highside supply capacitor.
The are chips that have both the low side and high side drivers within a single I.C. They also include a small delay between the two drivers activation to ensure both output MOSFET do not have any portion of time where they are both conducting, which would momentary short circuit the output supply.
Drivers are rated on their amperage output capability. It may sound strange but if you want to switch on or off a power MOSFET in a couple of hundred nanoseconds the current spike to do this can be quite high. Large MOSFET can have an input capacitance of 0.01 uF. This capacitance must be charged or discharge in the hundred nanoseconds.
RCinFLA is offline
Old 28th October 2009, 09:26 AM   #6
In industrial electronics, in PLC environments, where loads such as relays or electro-valves are far in the plant, high-side driver are preferred because a short between a conductor and "protection ground" (usually connected to 0V) will not fire the load. In PLC technical terms, this kind of outputs is called "PNP output".
For the same reason, inputs (pushbuttons, limit switches, ...) are usually connected to "high side" (+24V) and the input. This kind of inputs is also called "PNP input" even if it has no PNP transistor in the circuit.
Arkham00 is offline
Old 28th October 2009, 03:27 PM   #7
A high side MOSFET is when the source connects to the load. That is, the switch is BEFORE the load, or looking at most schematics, it's on the top side or high side of the circuit near VDD.
A low side MOSFET is when the source connects to ground. That is, the switch is AFTER the load, or it's on the bottom side or low side near GND.
Of course, this assumes NPN. If it's PNP, then it's all backwards.
smanches is offline
Old 30th October 2009, 12:04 AM   #8
The nice thing about a low side switch is that it is normally easy to drive, and the drive voltage need not be inverted ( that is + turns it on {I am also assuming a positive supply } ) and the drive voltage is usually less than or equal to the power supply voltage. If you use the right driver IC all this complication pretty much goes away.
Russ Hensel is offline
drivers, high, low, mosfet, side
low side battery MOSFET switch Hampton Electronic Projects Design/Ideas/Reviews 13 27th August 2009 03:35 AM
Using Low side drivers with high side P-Mos transistors Tradiator General Electronics Chat 9 30th June 2009 05:57 AM
Isolation and High-side or Low-side Brushless Motor Driver lobabob Electronic Projects Design/Ideas/Reviews 4 14th April 2007 12:23 AM
Simple High side N-Channel MOSFET driver clipo General Electronics Chat 10 5th April 2007 04:44 PM
High side or low side? Electronics4you General Electronics Chat 9 4th February 2007 04:30 AM
