+ Reply to Thread
Results 1 to 4 of 4
Thread: How Does A Fluorescent Ignitor Work?
  1. #1
    alisarhangpour Newbie
    Join Date
    Jul 2004
    Posts
    48
    Default How Does A Fluorescent Ignitor Work?
    Hi There!
    Can anyone tell me how a fluorescent ignitor works and what it's components are?
    Many thanks in advance.
  2. #2
    mahinda jayasinghe Newbie
    Join Date
    May 2004
    Posts
    106
    See the attached circuit diagram.
    When the switch ON, Voltage applies to both end of glow switch. Inside it there is a bi-metal strip which get heated and touch the other contact inside the golw switch. Then the circuit is complete and current flows through elements of tube located both end of the Tube. when the elements get heated, it emites electrons to the other ( discharge through the gas inside the tube glowing florescent meterial coated inside the tube)
    then circuit is completed through the tube and not current passing through glow switch. then bi-metal inside the glow switch cools down and disconnect the path inside the glow switch.
    Choke ( or ciol or ballast) is used as a current limiter through the circuit.
    If not , When discharge through the tube, it generate high current and eventually distroy the circuit.
  3. #3
    Klaus Newbie
    Join Date
    May 2003
    Location
    Australia
    Posts
    557
    Quote Originally Posted by mahinda jayasinghe
    There's a bit more to the ballast than just limiting the current. Completing the circuit through the starter bi metal switch also stops the 'glow' inside, allowing the bimetal elements to cool down and shortly open again.
    While this switch was closed the heaters on each end of the fluorescent tube got nice and hot but the tube did not fire as this requires a higher voltage.
    Now, as the bimetal switch opens, the magnetic field stored in the choke collapses, producing a high back EMF (~600V) voltage spike. This fires the fluorescent tube, the circuit is complete again with the electrons flowing through the tube, and THEN the ballast acts as a current limiter.
    Once the tube is lighted the voltage drop across it is less than that required to activate the bimetal 'glow' switch again, most of the mains voltage drop is across the ballast.
    You can observe this by carefully watching as a fluorescent tube is turned on. First there is a purplish glow in the starter, then the ends of the tube get orange hot inside, then there is a 'click' as the switch opens and the tube fires.
    If the fluorescent gas inside the tube gets exhausted the tube will try to fire but the electron stream is not strong enough to maintain the current and the tube flickers on and off as the starter continuously tries to fire it.
    Eventually one of the heaters at the tube ends expires and the annoying flicker stops but this could go on for many days if nobody comes and replaces the tube .
    If the starter is faulty there will be no flicker in the tube nor any glow from the starter.
    Klaus
  4. #4
    Join Date
    Jul 2004
    Posts
    48
    Thanks to Mahinda and Klaus,
    Is it the same in Metal Halide Lamp ignitors, Like
    Sodium lamps used to light up streets?
    These Ignitors have specifications like:
    Response Voltage, Cut-Out Voltage, OCV Open
    Circuit Voltage, etc. What are these specifications?
    Thanks, Ali
+ Reply to Thread
Tags for this Thread
