| | #16 |
It's part of Eagle. ULP = drill-aid.ulp John | |
| | #17 |
| drill-aid.ulp is the name. It draws additional pads in a new layer, with the inner diameter you choose.
| | #18 |
Hi all, If I am not wrong, it is not needed to create a separate library with the selected components. It will create some headaches like we need to save the library and if we install the later version of EAGLE means we need to update the library. It is very simple to use DRC in the EAGLE. If u open the DRC window means it has many tabs. Correctly enter all the values. The mains tabs for the homemade PCB's is the restring and the clearance tabs. Choose the appropriate values for them. I made the several circuits in the home. IF u want i will send the drc file of me. | |
| | #19 |
The biggest problem with using the restring tab in DRC is that it seems to affects all pads. That may not be what a user wants to do. In DRC is there a way to change the pads of just one component? John | |
| | #20 | |
3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
| | #21 |
The problem of having the printout smaller than the design size may be caused by the tranparency shrinking as it goes throug the printer. If you do not us heat stabilized transparencies the heat from the laser printer will cause them to shrink. This makes your printed image smaller than intended. If this is what is causing the error you can pre-shrink the tranparencies by sending them through the printer a few times, prining nothing. You can measure the actual page to see if it is smaller than before. | |
| eagle, make, pcb |
| Eagle PCB Making! | Wond3rboy | General Electronics Chat | 4 | 3rd November 2008 03:43 PM |
| Help Me in Printing PCB with Eagle | theo92 | General Electronics Chat | 11 | 28th August 2008 08:09 AM |
| Can someone make this PCB layout in Eagle for me? | moody07747 | General Electronics Chat | 1 | 27th April 2007 03:45 AM |
| Eagle - How to make Single Sided PCB | elexhobby | Electronic Projects Design/Ideas/Reviews | 5 | 14th October 2005 05:24 PM |
| LM7805 in Eagle PCB | computer | General Electronics Chat | 23 | 11th January 2005 08:54 PM |
