+ Reply to Thread
Results 1 to 3 of 3
Thread: Logic control exists in LDO
  1. #1
    alphacat Okay
    Join Date
    Apr 2009
    Location
    France
    Posts
    737
    Default Logic control exists in LDO
    Hello,
    Up until now I treated LDOs as black boxes which receive a certain voltage and produce constant (lower) voltage.
    I started reading a bit about its construction and I saw it uses a Logic control.
    What is this logic control for?
    And what is the device that the logic control feeds?
    Thank you.
  2. #2
    speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent
    Join Date
    May 2007
    Location
    USA
    Posts
    1,414
    Logic control is probably things like over-current and over-temperature limiting. Even very old regulators like the 7805 or 317 feature things like this.
    The rest of the circuit is just the analog feedback path that the logic control can disable. PMOS pass transistor, voltage comparator, internal voltage reference being compared to the voltage at the feedback/adjust pin.
  3. #3
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,821
    Blog Entries
    13
    Quote Originally Posted by alphacat View Post
    Hello,
    Up until now I treated LDOs as black boxes which receive higher voltage and produce constant (lower) voltage.
    Thank you.
    The logic is part of the ENABLE circuit, controlled from the Enb pin, to on/off the device.
+ Reply to Thread
  1. Cheap LDO (or quasi LDO) that will handle ceramic output caps?
    By speakerguy79 in forum Datasheet/Parts Requests
    Latest: 18th August 2009, 05:40 PM
  2. LDO replacement for 7805?
    By Krumlink in forum Datasheet/Parts Requests
    Latest: 11th September 2007, 12:33 AM
  3. Series/Parallel LDO or Zener + LDO?
    By dknguyen in forum General Electronics Chat
    Latest: 1st June 2007, 10:04 PM
  4. I need to know if a Circut or Part exists
    By Karaethon in forum Datasheet/Parts Requests
    Latest: 23rd January 2006, 06:18 PM
  5. Motor control VIA Logic and IR LED Beam
    By Johnson777717 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th March 2004, 05:21 PM
Tags for this Thread
