Hi Forum ,i am using a laser module, phototransistor SFH309-5, and 74HC14N (Circuit in the attachment) to detect the speed of the motor. On the Vout2 i measured frequency up to 2,8KHz when the speed of the motor is 28 000 RPM (because 6 reflected beam every rotation). But when i increase the motor to 32 000 RPM the frequency on Vout2 is 500Hz , and it should be 3,2KHz , what can be the problem ? Thank you in advance , | |
What voltage is Vcc?
R2 looks low to me. Try several higher values up to 20K. R1 looks low, too. Check that the current through the LED(I doubt that it is a "laser") is within spec.
__________________ Mike ML. | |
MAYBE YOU HAVE TO REPLACE R1 BY ANOTHER ONE LARGER to protect the laser module
Are you able to check it (the interuptor module),with another pulse counter?
| | #6 |
thanks for all , i change the value of R2 , it's now 10K , it's working well Have a nice day | |
| | #7 |
congratulations anita
| phototransistor, problem |
| phototransistor interfacing | pc88 | Electronic Projects Design/Ideas/Reviews | 0 | 30th January 2008 12:00 PM |
| phototransistor | ahmedragia21 | Robotics Chat | 10 | 30th May 2007 10:35 AM |
| Phototransistor vs Photodiode | mbu | General Electronics Chat | 33 | 31st March 2007 10:25 AM |
| help in phototransistor | 1111 | General Electronics Chat | 1 | 1st December 2004 05:39 PM |
| Replace a phototransistor | emusky | Datasheet/Parts Requests | 2 | 2nd August 2003 05:42 AM |
