Old 24th October 2009, 02:03 PM   #1
Default Opamp reference
I am wiring opamp in differential configuration . The non inverting pin has a divider 40K by 10K referenced to GND and the signal reference of 10V is to be aplied to one end of 40K resistor. My question is should this reference of 10V(REF01) require any buffering ?
dark is offline
Old 24th October 2009, 02:32 PM   #2
Post a schematic. Also describe the reference voltage generator, and post a schematic of it if possible.
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 25th October 2009, 02:27 PM   #3
Here is the schematic. Does the reference IC requires a buffer?
dark is offline
Old 25th October 2009, 03:06 PM   #4
I don't know what the IC is, but 50K is alot of resistance, so I'm going to say that a buffer is not required.
ball.
BrownOut is offline
Old 25th October 2009, 03:15 PM   #5
In my first post I say the number REF01 .
dark is offline
Old 25th October 2009, 03:21 PM   #6
No buffer required.
ball.
BrownOut is offline
Old 25th October 2009, 03:59 PM   #7
No buffer required.
Thanks , can you help me with how/what to look for in the REF01 specs . It doesnt says how much load can it drive?
dark is offline
Old 25th October 2009, 04:00 PM   #8
There is a spec for load regulation, given in ppm for 0 - 10 mA
ball.
BrownOut is offline
Old 25th October 2009, 04:20 PM   #9
I am sorry I checked it again and again http://www.analog.com/static/importe...eets/REF01.pdf but couldnt locate the said spec in ppm , but ony a work case regulation of 0.012%/V for REF01H on page 3 .
dark is offline
Old 25th October 2009, 05:04 PM   #10
It's given in %/mA on page 3.
ball.
BrownOut is offline
Old 26th October 2009, 09:26 AM   #11
Thanks for the help , that was a typo on my behalf "%/V" .
dark is offline
opamp, reference
voltage reference electricity86 Electronic Projects Design/Ideas/Reviews 6 25th December 2008 04:43 PM
Using a voltage reference SMUGangsta General Electronics Chat 33 21st October 2008 04:51 PM
Shunt reference and Series reference Arunmurugesh General Electronics Chat 4 3rd September 2008 09:36 AM
why REFERENCE pin is used? raviram87 Electronic Projects Design/Ideas/Reviews 1 5th April 2008 12:18 PM
Voltage reference ic for A/D Exo Micro Controllers 3 25th July 2005 12:58 AM
