+ Reply to Thread
Results 1 to 5 of 5
Thread: need help to understand tis circuit
  1. #1
    aruna1 Newbie
    Join Date
    Aug 2008
    Location
    Sri Lanka
    Posts
    172
    Default need help to understand tis circuit
    this is the circuit of JDM programmer.
    I'm trying to understand how Q2 works here.coz only base of Q2 get a voltage and emitter or collector is not connected to power supply,
    there is a description about this circuit,but I cant understand that description.
    here is the circuit
    and this is the description
    PIC Programmer 2, Describtion.
  2. #2
    dougy83 Good dougy83 Good dougy83 Good
    Join Date
    May 2008
    Location
    Brisbane, Australia
    Posts
    756
    It's a bidirectional level translator. Assuming DTR is high: If the PIC pulls the data line (the emitter of Q2) low to -5V, the base-emitter is forward biased and the collector is pulled down to ~-5V also. If the PIC doesn't pull the emitter low (-5V), or sets it high (0V), then there is no bias for the transistor and it won't be conducting and the collector voltage will be set by DTR.
    If DTR is low, the transistor base-collector is forward biased, and the emitter is pulled low.
  3. #3
    aruna1 Newbie
    Join Date
    Aug 2008
    Location
    Sri Lanka
    Posts
    172
    Quote Originally Posted by dougy83 View Post
    i dont think PIC can produse negative voltages
  4. #4
    Join Date
    May 2008
    Location
    Brisbane, Australia
    Posts
    756
    Quote Originally Posted by aruna1 View Post
    Well this must be a magic PIC. You'll note that the PIC vdd is GND (0V). Vss is -5.1V. So in this setup it will be hard for the PIC to produce positive voltages.
  5. #5
    aruna1 Newbie
    Join Date
    Aug 2008
    Location
    Sri Lanka
    Posts
    172
    in this setup it uses negative voltage to make voltage double
+ Reply to Thread
  1. Need help to understand this circuit
    By mischa in forum General Electronics Chat
    Latest: 8th October 2009, 01:08 AM
  2. i cant understand somt part of this circuit..
    By transgalactic in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th May 2008, 02:51 AM
  3. don't understand circuit operation. please help!
    By danae_fiz in forum General Electronics Chat
    Latest: 4th March 2008, 01:44 PM
  4. plz give an idea fr tis atleast..
    By zahir hussain in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st March 2006, 01:04 PM
  5. CANT UNDERSTAND THIS CIRCUIT HELPPP PLSS!!
    By cyprio7 in forum General Electronics Chat
    Latest: 3rd October 2005, 03:55 AM
Tags for this Thread
