Old 29th October 2009, 11:04 AM   #31
Originally Posted by Airian_007 View Post
Thank You bountyHunter
But the main Problem is
i am confused about the voltage and current requirement for the led so
plz give me some information about the voltage and the current ratings of some different led's
and some math to calculate resistance
i am waiting for reply
once again thanx
Look at these images, the current depends upon the LED type, which type do you have.?
Capacitor to remove LED flicker-ledcolours.gif   Capacitor to remove LED flicker-ledfwd1.gif
ericgibbs is offline
Old 30th October 2009, 01:38 AM   #32
Airian generally you don't calculate a resistance for a diode, because it changes dynamically with the voltage/current going through it and it's temperature, though you can make observations.
A simple example is a common white LED might be rated at 3.6 volts forward @ 20mas of current, which works out to being the same as a 180 ohm resistor. A diode is not linear though, say for example you increase the voltage to 3.7 volts you would expect a 180 ohm resistor to only increase it's current from 20ma to 20.56ma where as an LED could increase to 25ma or more. Experimentation and observation will teach you better than a data sheet or personal testimonies will.
straight answer, har har."
Sceadwian is online now
Old 31st October 2009, 10:58 AM   #33
Thanks For The Information
God Bless You
I Have White LED's
Airian_007 is offline
capacitor, flicker, led, remove
How we can make this emergency lamp flicker 89Panadol Electronic Projects Design/Ideas/Reviews 8 17th October 2009 04:54 AM
Inverter to make 110v LEDs NOT flicker? WardXmodem Electronic Projects Design/Ideas/Reviews 31 28th January 2009 06:17 PM
led flicker lippyjohn Electronic Projects Design/Ideas/Reviews 12 9th January 2006 06:43 AM
Generation of a Random Flicker Effect? davepusey Micro Controllers 16 1st June 2004 09:35 PM
Off-Topic: How to reduce flicker on the graphic LCD? thomasn102 Electronic Projects Design/Ideas/Reviews 6 8th March 2004 01:21 AM
