Hi guys, I have some questions about running 12ax7 preamp tube heaters on DC. The filaments are pins 4,9ct, 5. Typically they are run at 6.3 VAC in parallel ..pins 4&5 connected to one leg of Ac and pin 9(center tap of the filament) to the other leg of ac. In parallel the current draw is 300ma. I'd like to run multiple tubes on regulated 12.6 DC. The filaments will be run in series, pin 9 not used. In series the current draw is 150ma. How do you wire this? Put 12.6 DC on pin 5s and wire pin 4s to ground? Is it that easy? Or what am I missing? Thanks! | |
It is just that easy. Leave pin 9 open. When running multiple tubes, they will be wired in parallel with the first tube.
__________________ Mike ML. | |
Vacuum tubes?? Welcome to the distortion of 1950.
Or the Marshalls of the 1970's! ![]() 'Cmon Audioguru... don't you like the sound of smooth tube amps over solid state? | |
| | #5 | |
'Smooth' isn't an audio term, but means low quality, poor frequency response and high distortion. | ||
| | #6 |
In 1950, solid state amplifiers had crossover distortion and no high frequencies. Then tube amplifiers sounded distorted but better. How times have changed today. Now solid state amplifiers have distortion so low that it is difficult to measure and their frequency response is a straight line from DC to green light.
| | #7 | |
Use A when A is best, use B when B is best, and be smart enough to know which is best and when. | ||
| | #8 | |
I think some people confuse the "smooth" characteristic of tubes with the pleasing sound of even order harmonic distortion, the kind you get with a class A amplifier where the top half of the waveform is compressed. I adds a nice "chorus" effect to the sound.
__________________ -=VA7KOR=- My Solar System Includes Pluto. Last edited by Bob Scott; 23rd October 2009 at 08:29 AM. | ||
| | #9 |
I like what RB said... "Use A when A is best" As a guitar player for almost 20 years, I've had several of both and it really just depends on what genre you want to sound like. Both have their pros & cons. But hey, if it sounds good... | |
| | #10 | |
If you want such a coloured sound a valve amp is the best way to go. | ||
| | #11 |
Sure they affect the sound, but with modern instruments (say electric guitar) the amp is very much a PART of the instrument. As an example you could say the spruce top of a classic violin gives it a "smooth" sound by attenuating the high frequencies. You could make the violin top out of high tensile steel and it would have "much better high frequency response" but then it would sound tinny, harsh etc. Having an instrument where all the frequencies are reproduced equally is NOT a guarantee it will sound better. | |
| | #12 | |
| | #13 |
You don't need to use a vacuum tube amplifier to rolloff the high frequencies. A tone control circuit will do the same but will not add distortion like vacuum tubes unless the tone control circuit also has vacuum tubes.
| | #14 |
Question: How many engineers does it take to answer a question about series-parallel connections? Answer: ONE to answer the question; and FIVE to argue about deep-seated personal preferences!
| | #15 |
Dude... this is more than a preference... it's a Jihad!
| circuit, heater, preamp, tube |
| Tube Preamp Schematic | reap461 | Electronic Projects Design/Ideas/Reviews | 0 | 24th October 2008 11:11 AM |
| Need help in 88-108MHz preamp circuit!! | rahulan999 | Electronic Projects Design/Ideas/Reviews | 156 | 19th October 2008 05:44 PM |
| electret Microphone with preamp circuit | ivanseng | Electronic Projects Design/Ideas/Reviews | 5 | 29th February 2008 06:49 PM |
| Audioguru Please See My Simple PreAmp Circuit | Gayan Soyza | General Electronics Chat | 11 | 8th May 2007 03:58 AM |
| Heater Circuit | kgi333 | Electronic Projects Design/Ideas/Reviews | 1 | 16th October 2005 05:25 PM |
