+ Reply to Thread
Results 1 to 6 of 6
Thread: Soldering terms ques
  1. #1
    kentken Newbie
    Join Date
    Jan 2004
    Location
    Washington State
    Posts
    224
    Default Soldering terms ques
    That are soldering pastes, and there uses?
    What is soldering mask, and uses?
    What are some others, and there uses?
    Kent
  2. #2
    Exo
    Exo is offline
    Exo Newbie
    Join Date
    Sep 2003
    Location
    Belgium
    Posts
    1,884
    Default Re: Soldering terms ques
    Quote Originally Posted by kentken
    Kent
    Soldering paste or flux is required to make the solder flow nicely over the contact when soldering. without it the solder would tend to stick to the soldering iron, the contact would be soldered bad.
    soldering mask is the 'green paint' you see on commercial boards. commercial boards are ofthen wave soldered, wich means the pcb is dipped into a pool of solder, the sodering mask makes the solder stick only to parts where no 'paint' was applied...
  3. #3
    kentken Newbie
    Join Date
    Jan 2004
    Location
    Washington State
    Posts
    224
    What is the difference between soldering paste and Flux?
  4. #4
    k7elp60 Excellent k7elp60 Excellent k7elp60 Excellent k7elp60 Excellent k7elp60 Excellent
    Join Date
    Oct 2003
    Location
    Utah
    Posts
    926
    The only difference that I know about is that paste is usually in a paste form and applied with an applicator. The flux is generally in liquid form and may be applied with a different applicator. A lot of solder has the flux within the core of the solder. There are different types of flux, some are water soluable, meaning they will wash off with water. The oldest and the most common for small soldering jobs is not washable with water, but cleans well with alcohol. Fux for plumbing is different and should not be used on electronic or electrical connections and it can cause corrosion of the joint.
  5. #5
    Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent
    Join Date
    Feb 2003
    Location
    Harviell MO USA
    Posts
    956
    There's a BIG difference between soldering paste and solder paste. Soldering paste is a flux. Flux is available in either liquid or paste form and used as the cleaning agent to remove contaminants while soldering.
    Solder paste is a mixture of tiny balls of solder and flux, used for mounting SMT devices in place of regular solder. It's usually applied rubber-stamp fashion (e.g., silk screen) and a board is populated with parts and run through an oven to melt the paste on all the parts simultaneously. It's the SMT version of wave soldering. Solder paste is expensive stuff and is available in small tubes for hobbyist use or for repair.
    Dean
    R.I.P.
  6. #6
    samcheetah Newbie
    Join Date
    Dec 2003
    Location
    Pakistan
    Posts
    874
    what do u people use for a normal solder joint. by normal i mean through hole components (resistors, capacitors, DIP ICs)
    i just use a flux cored solder. i havent used solder paste because i have never worked on small soldering jobs.
    is there any benefit in using soldering paste before u apply the joint
+ Reply to Thread
Tags for this Thread
