I have noticed there are many ferrite types, what do they mean and what is best for joule thief circuit? For example: FERRITE RING CORE, 6.3X3.8X2.5, N30 Ferrite Grade:N30 External Diameter:6.3mm Internal Diameter:3.80mm Ae Effective Cross Section Area:3.06mm˛ Al Tolerance Value +:25% Effective Magnetic Path Length:15.21mm External Diameter:6.30mm External Length / Height:2.5mm Inductance Factor, Al:1090nH Internal Diameter:3.80mm Also does it matter how many windings I have some say 10 others 20, 50 etc. Does it make sense to make more or it just changes frequency? | |
The Joule Thief isn't a really critical circuit. It works with a wide variety of cores (even a nail). I suggest that you try different stuff on the bench. Be aware that simulation doesn't always work! Your simulator must understand saturation of the transistor and inductor.
__________________ de KI6RWX | |
Any grade ferrite will be fine for a joule thief. The type is only critical in stuff like RF and power conversion applications where you care about frequency characteristics and saturation. A little old joule thief won't care what you use.
I can't comment on the requirements of the joule thief. If you want to know more take a look here: https://www.amidoncorp.com/pages/specifications If you focus on a toroidal (like a donut) core you'll see a lot of information that can be confusing. One factor that tells a lot is the Al - which more or less describes the number of turns required per unit of inductance. A higher Al suggests that less turns is required for a given amount of inductance. Many of the suppliers (Amidon, Micrometals, Fair-rite, etc) provide some simplified applications information - suggesting materials that are better suited for an application.
__________________ stevez | |
I ask because I tried some green and yellow cores and they did not seem to work, when I use black (graphite color) core it did.
| | #6 |
| you need to use ferrite cores and not Iron powdered cores , those are used in RF communication and may not offer the high AL values needed for circuits like Joule thief. perhaps you may use torroids that are found in electronic ballasts.
__________________ Regards, Sarma. Last edited by mvs sarma; 29th October 2009 at 05:48 PM. | |
| ferrite, grade, joule, thief |
| Blinking joule thief | anfegori91 | General Electronics Chat | 12 | 16th November 2009 10:36 AM |
| Using a Joule Thief as a bootstap | Hero999 | Electronic Projects Design/Ideas/Reviews | 18 | 8th May 2009 09:44 AM |
| Another joule thief. | Sceadwian | General Electronics Chat | 47 | 13th April 2009 04:35 AM |
| Need HELP !!! : Joule thief | firdaus93 | Alternative Energy | 8 | 7th April 2008 03:57 AM |
| The joule thief | Armagdn03 | General Electronics Chat | 1 | 22nd October 2007 11:01 PM |
