Smanches,
Yes I did mention that. I was under the impression that the voltage induced by a magnetic field was delayed 90 degrees and if the amperage is delayed 90 degrees from the voltage then there is a distribution of 180 degrees between the three roughly. Isn't that correct?
The voltage reflects the change in magnetic field, from full positive to full negative of a magnetic field the the voltage is one polarity and then from full negative to full positive the voltage is the other polarity. its out of phase 90 as well.
