+ Reply to Thread
Page 3 of 4
First 1 2 3 4 Last
Results 31 to 45 of 59
Thread: Understanding AC phase relationship...
  1. #31
    smanches Excellent smanches Excellent smanches Excellent smanches Excellent smanches Excellent
    Join Date
    Mar 2009
    Location
    Oregon, USA
    Posts
    886
    I'm not sure that post helped the OP either. He just wants to know how to measure the power-factor out of a coil being induced by a magnetic field.
    dev, easiest would be to measure the peaks of both current and voltage, then calculate how much time they are out of sink.
    if time == 0 then they are in phase == 1.0 PF
    if time == 1/4 freq period then they are 90degrees out of phase == 0.0 PF.
    Just interpolate the rest based on the wave form.
  2. #32
    Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent
    Join Date
    Mar 2006
    Location
    Michigan, USA (GMT-5)
    Posts
    2,892
    Quote Originally Posted by smanches View Post
    As I read the original question it was not about measurement, but a theoretical query about weather in an inductor with some parallel resistance is it possible to have the current and voltage in phase giving a power factor of 1. My answer is that it is not. We have a difference of opinion which can be settled by either a coherent theoretical proof or by experiment. However, even in the face of overwhelming evidence some people will remain unconvinced. This appears to be such a case, and thus it is pointless to continue this thread.
    We never have time to do it right; but we always have time to do it over.
  3. #33
    devronious2009 Newbie
    Join Date
    Aug 2009
    Posts
    26
    smanches,
    I currently can't measure the peaks as I have no oscilliscope at the moment. I will buy one eventually, but for now I'm out of luck, I can only calculate. And that is what I must do I guess. Although I would love to get my hands on an oscilliscope, I think I soon will.
    I'm really interested in formulas for calculating phase, I'll look at the PDF now and see if I can use something in there.
    Guys, I calculated the inductive reactance earlier and used it to calculate the amperage at different points, is that the correct way to do it? I got in phase amperage and voltage, which makes me think its incorrect since I calculated it at 6khz which everyone seems to agree is out of phase.
  4. #34
    Join Date
    Aug 2009
    Posts
    26
    ke5frf,
    I got into the PDF and noticed that I can get the phase angle from the reactive inductance of the coil. Basically theta equals the arctan of the reactive inductance.
    So my question is this: does my value for the reactive inductance change at different points along the voltage wave, or is it a constant value throughout the wave?
    I think that may be the answer I'm looking for. Thanks.
  5. #35
    ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    devronious,
    Glad the pdf helped...I didn't write it, just Googled it.
    There is a point with all the math and trigonometry where my brain starts turning to mush and the concepts begin to confuse me. Probably why I'm not an engineer.
    So I will defer explaining the math to someone more qualified.
    And I certainly HOPE that some of the things I mentioned helped reinforce your understanding of the theory. In fact, I would appreciate feedback about that. The Cebik webiste I linked to, if you are so inclined, will open your eyes in a lot of ways. If you get time I highly encourage some reading.
    Good luck with digging into all the math and modelling this with software.
  6. #36
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,026
    Quote Originally Posted by ke5frf View Post
    You bring up real vs reactive and seem to imply that "real power" is some way more desireable than reactive power, or more "real", LOL, which is a deceptive word. If all electronic circuits were designed to energize light bulbs, turn a motor, etc, then you might have a point. However, this is not the case thankfully or my cellphone and radio equipment wouldn't work.
    In radio, in fact, REACTIVE power is the desireable power and "real power" is what we seek to mitigate.
    Real power is real power, independent of the application or frequency. You seem to be confusing reactive power with the radiated power from an antenna. Real power is the power that goes out the antenna and is indeed the desirable power. If you have an antenna perfectly matched to the transmission line characteristic impedance driving it, then it will look like a resistance (i.e. the RF current is in phase with the voltage), there is no reactive power, and all the real power is radiated. That is the whole point of tuning the antenna to match the transmission line and minimizing SWR. You only get reactive power if the antenna is mismatched. Reactive power does no work and is generally undesirable.
    The phrase "reactive power' is somewhat of a misnomer since there is no power involved in the normal sense of the term. It is more accurately called imaginary power since it can have a value of volts times amps, but it does no work.
    Carl
    Curmudgeon Elektroniker
  7. #37
    Join Date
    Mar 2009
    Location
    Oregon, USA
    Posts
    886
    Quote Originally Posted by Papabravo View Post
    Although he said when being induced by a magnetic field. This is the difference that makes it have a PF of 1.
  8. #38
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    OK, I am comfortable with being incorrect with some terms and some concepts. I do not wish to contribute to any confusion. It has, admittedly, been a while since I studied or applied much of this stuff, and...use it or lose it so to speak.
    I do feel like I've mixed up a thing or two in my own mind so I'm going to dig out some books and read.
  9. #39
    Join Date
    Mar 2009
    Location
    Oregon, USA
    Posts
    886
    I'm digging into it all right now too. There is almost no information about the phase relationship on the output windings of transformers.
    I'm just going to have to setup the experiment at home tonight, since simulation does not seem to satisfy everyone.
  10. #40
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    OK, perhaps this is where I am wrong or misunderstand...Or perhaps I am right or half-right. Whatever.
    RADIATION OF ELECTROMAGNETIC ENERGY
    I know this thread is about coils and transformers, but it has always been my understanding that AC theory is the same "forest" despite differences in the "trees", so that is why I keep going back to RF transmission and antennas.
    On the page I linked, it states this:
    4-6 1. A current flows in the antenna with an amplitude that varies with the generator voltage. 2. A sinusoidal distribution of charge exists on the antenna. Every 1/2 cycle, the charges reverse polarity. 3. The sinusoidal variation in charge magnitude lags the sinusoidal variation in current by 1/4 cycle.
    A 1/4 cycle is 90 degrees out of phase.
    At the top of the page, if you click "previous page", (not the windows icon, but rather the link provided on the page) you see the same depiction from the Cebik site showing current and voltage distribution, 90 degrees out of phase.
    I have always concluded that in a properly tuned antenna system that voltage and current where not in phase.
    Yet in doing a little reading of other webpages I'm getting some contradictions.
    So it definately looks like reading an actual BOOK instead of the internet, to refresh, is in order LOL.
  11. #41
    Join Date
    Mar 2009
    Location
    Oregon, USA
    Posts
    886
    I would agree with that as well, but in this case you're inducing the current from the voltage in the line. And it would be inline with how an inductor works when being induced by voltage. It's the back EMF that is causing them to go out of phase.
    OP asked if he generates the current from a magnetic field; that is a generator. In this case, everything I can find (which I admit is almost nothing so far) shows them both to be in phase. In this case, there is no back EMF, so there should be no phase difference.
    The real question is whether generators produce voltage and current waveforms that are in phase with each other. I would have to think yes, otherwise PF correction would be dependent on the specific generator as well as the load, not just the load.
  12. #42
    Join Date
    Aug 2009
    Posts
    26
    OK I modeled the software via the PDF and used the arctangent of the Inductive Reactance. I get the following:
    Does that seem right? The amperage is 90 degrees behind the voltage. And the frequency only very slightly changes that by like a hair. The lower the frequency the further off from 90 it is, but again only slightly.
    Also I'm aware that the amplitudes are not correct, but I'm really only concerned with the angle.
  13. #43
    Join Date
    Mar 2009
    Location
    Oregon, USA
    Posts
    886
    Yes, that would look correct if you are sending a signal through an inductor. But didn't you mention that you are supplying the magnetism itself to induce the current/voltage?
  14. #44
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,026
    I believe the confusion is the phrase "variation in charge magnitude lags the variation in current". It does not say the variation in current lags the voltage. The variation in current is in phase with the voltage, but out of phase with the variation in charge. Make sense?
    Also again regarding a generator, transformer or any induced voltage in a coil: Smanches is correct. The voltage is in phase with the magnetic change. Any phase shift at the output is due to the reactive charactistics of the load. It is not due to any inherent inductance of the transformer/coil/generator (ignoring stray or parasitic inductance).
    Carl
  15. #45
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    Quote Originally Posted by crutschow View Post
    No, I don't think there is confusion.
    Further reading from the same article:
    Figure 4-6.—Standing waves of voltage and current on an antenna
    "Look at the current and voltage (charge) distribution on the antenna in figure 4-6. A maximum movement of electrons is in the center of the antenna at all times; therefore, the center of the antenna is at a low impedance. This condition is called a STANDING WAVE of current. The points of high current and high voltage are known as current and voltage LOOPS. The points of minimum current and minimum voltage are known as current and voltage NODES."
    And if you refer the diagrams, the point of high current "loop" is at the place where voltage is zero, or the voltage "node", and where current is zero, there is a voltage loop...and the voltage loop corresponds to areas of high charge magnitude.
    I realize that voltage and charge are two different things, but that doesn't mean they aren't related, or rather aren't UNRELATED.
+ Reply to Thread
Page 3 of 4
First 1 2 3 4 Last
  1. start of relationship
    By alphadog in forum Chit-Chat
    Latest: 13th February 2009, 12:16 AM
  2. Relationship between SWG and AWG
    By Boncuk in forum General Electronics Chat
    Latest: 18th July 2008, 02:30 PM
  3. DC motor relationship
    By westkid85 in forum General Electronics Chat
    Latest: 1st May 2008, 12:23 PM
  4. relationship between electronics and programming
    By Mark S. in forum General Electronics Chat
    Latest: 5th September 2006, 07:58 PM
  5. Processor Motherboard relationship
    By fsahmed in forum General Electronics Chat
    Latest: 2nd August 2005, 04:27 PM
Tags for this Thread
