Old 21st October 2009, 02:01 PM   #1
Exclamation Internal Factors?/Series Ω
Internal Factors on which Power Rating of a Semiconductor Diode/Transistor Depend on...Please Justify the Answer (What abt the Diode Drop?What does that depend on?)
Another Ques is Why Series Resistors are used in Diode Circuits(to limit current)?
Why cant the Voltage be reduced? */anyhow both of them make voltage across diode same\*
Thanks in Advance
r.vittalkiran is offline
Old 21st October 2009, 04:02 PM   #2
Power rating is primarily based on the ability of a system to get rid of heat. There are basically thrre methods which are conduction, convection, and radiation. Mounting a semiconductor to a heatsink is an example of conduction. A cooling fan is an example of convection. Black anodizing a heat sink is an example of radiation.
If you look at the equation of a diode you notice that the current is an exponential function of the forward voltage. Past the threshold of about 0.7V, small increases in the forward voltage produce large increases in forward current. At some value of forward current the device will proceed to get warm, hot, and vaporize. It is the vaporization that effectively limits the current without a resistor. It should not be a surprise that this thermodynamic process is not reversible. So far as I know there have been no recorded cases of molecules spontaneously forming a diode.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 23rd October 2009, 03:24 AM   #3
for second question:
When a circuit at 0V potential is first connected to power, the difference may cause an instantaneous current beyond the rating of the diode (and other devices). A proper value resistor can limit this current to a (large) safe current. In normal operation the steady current isn't infinite so the resistor's losses hopefully are acceptable.
de KI6RWX
mneary is online now
Old 23rd October 2009, 01:03 PM   #4
Smile
Thanks...But what makes it happen so?
what happens when i connect the power supply aftersome time? i.e,. First switch it ON, and then connect!??
Old 25th October 2009, 05:11 AM   #5
Attaching two different potentials together causes current to flow. It continues until they are equal. If there is no resistance in the path between them, the current is infinite (in real circuits it can't be infinite, so it is large).
de KI6RWX
Old 29th October 2009, 03:10 PM   #6
Cool
If this is Right, then why cant i use a Low Voltage, so that its obvious that current will be less(Required Amt.), now no need of Resistor???? :P ..
Ω, factors or series, internal
Factors on which wattage of electric bulb depends r.vittalkiran General Electronics Chat 14 13th September 2009 03:13 AM
Reprogramming PICs with Internal OSC on & MCLR disabled (internal) Inchworm+ blueroomelectronics Micro Controllers 5 11th April 2007 05:10 PM
Interfacing 4000 series CMOS to 74HC series TTL kd4pbj General Electronics Chat 11 22nd January 2007 05:53 PM
Difference between 4000 series and 7400 series? ghall426 General Electronics Chat 17 1st January 2007 02:01 AM
Voltage divider with 10kΩ potentiometer SPDCHK General Electronics Chat 5 27th December 2006 11:03 AM
