I'm trying to reproduce a pull alarm from radio shack. I took it apart and followed the lines with the beep setting on the multimeter. The silicon black spot was scratched off with a razor blade. Unable to tell how it was connected inside there. I think have got as far as possible for myself and need some assistance. What exactly is the bottom round thing with three connectors? I was thinking a capacitor of some sort. The red wire is bent and only connects to 21. I also want to add another pull section, which was the main reason for disassembly. The pull part is the rectangle on top. Here are the pictures. Last edited by fairlight; 21st October 2009 at 02:59 AM. | |
| | #2 | ||
it connects to the 'pull switch' connector; when the string is pulled out, 21 is connected to the rest of the circuit and provides power for it to screech. | |||
I wonder if the IC can be substituted for a opamp chip or something? It's probably impossible to find out the part number for the IC. Suitable replacement? As for getting another pull trigger installed, I may try connecting wires to 12 and 14 to something, ground maybe? Then try another wire connected to 13 as the trigger wire. Here is a picture of the whole alarm in case anyone recognizes it. | |
| alarm, pull |
| Pull-up and pull-down configuration of pins. | electricity86 | Micro Controllers | 10 | 7th July 2009 07:49 PM |
| alarm circuit for alarm clock | skinnie339 | Electronic Projects Design/Ideas/Reviews | 2 | 26th April 2009 01:41 PM |
| MCLR, Pull-up,Pull-down with ICD2 clone | GRC | Micro Controllers | 2 | 2nd January 2007 12:52 AM |
| Must I use Pull-up / Pull-down Resistors? | Andre1 | General Electronics Chat | 3 | 28th December 2006 10:52 AM |
| pull-up and pull-down resistors with IC's | mstechca | General Electronics Chat | 14 | 7th January 2006 04:08 AM |
