Old 20th October 2009, 07:43 PM   #1
Thumbs up Resister value calulation
Hi in my design i am using 24 volt 8 amps relay.I that circuit to check the relay status iplan to add one led. I want to know that value of that rsister and how to calculate.
Can anyone help to solve this issue.
Mr KAR is offline
Old 20th October 2009, 07:48 PM   #2
[24V - (2 to 3 V)]/20mA = Resistor.
Where do you plan on putting the led, will it be a basic on/off indicator?
Mike
My website: www.ElectroBird.net
birdman0_o is offline
Old 20th October 2009, 07:52 PM   #3
thanks i want to check relay is active or not so that i plan to add led.
yes basic on/off indicator
Mr KAR is offline
Old 20th October 2009, 08:30 PM   #4
Yea what I said will work. Just put it in parallel with the other circuitry the relay is turning on.
Mike
Old 20th October 2009, 08:35 PM   #5
Thanks. I choose Forward volt 2.3v. So your Calculation shows 1.1k.
Mr KAR is offline
Old 20th October 2009, 08:46 PM   #6
The foward voltage will depend on your specific led, you can find it in the datasheet. 1.1K sounds right for the value you have chosen.
Mike
Old 20th October 2009, 09:47 PM   #7
ya thanks in my datasheet shows forward voltage 2.3.
Thanks for youe help
Mr KAR is offline
Old 20th October 2009, 09:59 PM   #8
If you put the LED and resistor across the relay coil instead of the contact load, you can have any value of voltage or type (AC or DC) on the relay contacts without it affecting the LED circuit operation.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 20th October 2009, 10:02 PM   #9
I can't picture this Carl, do you have a schematic handy?
Mike
Old 20th October 2009, 10:09 PM   #10
Relay contact rating is 8A @ 250VAC/30VDC(NO):8A @ 250VAC; 4A @ 30VDC(NC)
I don't have any schematic.
Mr KAR is offline
calulation, resister
What value of resister and LED rsracing1 Electronic Projects Design/Ideas/Reviews 4 19th April 2009 03:56 PM
RA4 Pull up Resister Value Suraj143 Micro Controllers 5 17th January 2009 08:00 AM
calulation software vobla General Electronics Chat 15 15th March 2008 01:35 AM
Resister help...Please ghoattriple General Electronics Chat 2 3rd September 2004 05:29 PM
