+ Reply to Thread
Results 1 to 8 of 8
Thread: SMD component identification !
  1. #1
    aljamri Okay
    Join Date
    Jun 2006
    Posts
    278
    Default SMD component identification !
    Hi again,
    Attached is a photo for a similar component to a blown one in a faulty card I'm trying to repair. As an prehistoric technician, I'm not much familiar with SMD so, I do not know what are these two components.
    I do contact EBCOS company and amazingly, the swift reply me, the yellow one is " tant chip capacitor" when I asked about its value and the identity of the black component, they gently excused that they can not help me.
    Any body can help for the value of the yellow capacitor and the identity of the black one.
    Its what your friend in Your mind, what you in your friends mind
  2. #2
    colin55 Bad colin55 Bad
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    107 = 100u 10v
    22 35 = 22u 35v
  3. #3
    aljamri Okay
    Join Date
    Jun 2006
    Posts
    278
    Thanks for your help, for the black one, similar idea came to my minde, but the 2N diverted the whole things.
    Is there any problem -except for the space- to replace them with the ordinary snap capacitors.
    Thanks again.
  4. #4
    justDIY Good justDIY Good
    Join Date
    Mar 2005
    Location
    Michigan, USA
    Posts
    1,725
    colin nailed the values, both are tant caps, and the line indicates positive, unlike the line on a diode or aluminum electrolytic cap which indicates negative!
    without seeing more of the board, can't tell you what an appropriate replacement, other than the exact same thing, would be. sometimes tant are used because of low esr, high frequency, etc. sometimes they're just used because they offer high capacitance in a small size.
    If you don't have a planet, what good are gold bars?
    want to contact me directly? gmail gordonthree
    check out my project website: http://projects.dimension-x.net
    Favorite numbers:
    09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
  5. #5
    Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,807
    Quote Originally Posted by justDIY View Post
    Isn't it weird though that the negative end connects to the positive rail in a bridge rectifier.
    Just kidding.
    noptical Newbie
    Join Date
    Mar 2008
    Posts
    7
    Quote Originally Posted by aljamri View Post
    Hi again,
    Hi
    You can find tantalum caps in 10packs on ebay and they're very cheap.
  7. #7
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    the line on a diode indicates negative
    The line on a diode indicate cathode (k) (kathode) NOT NEGATIVE - the cathode end of the diode may be connected to the negative rail or the postive rail of a circuit (or anywhere in-between), but the black or silver or red stripe or indent or dot or chamfer or symbol on a diode ONLY INDICATES THE CATHODE. Nothing else.
  8. #8
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    However in order for a diode to pass current the cathode has to be negative in relation to the anode. Thinking the diode cathode itself actually represents a negative voltage is a bad habit to get into like I think Colin was trying to say.
    straight answer, har har."
+ Reply to Thread
  1. Component Identification
    By Kamil_NJ in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th March 2009, 12:34 AM
  2. Component identification?
    By codan in forum General Electronics Chat
    Latest: 6th April 2008, 07:24 AM
  3. Component identification
    By Trevor Rymell in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th November 2006, 08:28 PM
  4. SMD MOSFET help with identification please
    By HandyMan in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th January 2005, 10:00 PM
  5. SMD Component Identification
    By Shivleo in forum General Electronics Chat
    Latest: 25th July 2003, 02:27 PM
Tags for this Thread
