Old 20th October 2009, 03:38 AM   #1
Default Generator
How do you determine the voltage of the generator?
I m suppose to produce electricity by doing a bicycle generator but i m not sure what voltage generator should i use and why.
Anyone can help me?
Tuck3rz is offline
Old 20th October 2009, 03:44 AM   #2
The voltage will depend on the flux and amount of coils if you want to look at it from a mathematical perspective. If you want to look at it on the quantitative side, in an ideal situation, a 24V motor can produce 24V while being turned at the RPM it would normally spin at when attached to a 24V power source. This is for DC motors of course, you could also look into Stepper motors.
Mike
My website: www.ElectroBird.net
birdman0_o is offline
Old 20th October 2009, 03:44 AM   #3
Spin the motor shaft... measure the voltage produced under load....
straight answer, har har."
Sceadwian is online now
Old 20th October 2009, 03:51 AM   #4
meaning, if i were to use the dc motor to charge a 12V battery, i just have to use a 12V generator?
Tuck3rz is offline
Old 20th October 2009, 03:53 AM   #5
That topic has been covered on the forums multiple times and the information is easily searchable on Google.
Old 20th October 2009, 03:58 AM   #6
It would be a bit more complicated than your simplification. You would need to maintain over 13.8V to charge a lead acid battery. 12V would essential be its peak voltage. If it were up to me I'd use a 24V motor with a 12V lead acid battery, and would gear the motor to ouput ~14.5-15V.
What is going to be turning the motor?
Mike
Old 20th October 2009, 04:05 AM   #7
a bicycle which is used to turn the generator and it is connected to a charge controller then to a 12volt lead acid battery
Tuck3rz is offline
Old 20th October 2009, 04:10 AM   #8
alternatively, the generator is also connected to a series of LED and 7-segment to show the amount of voltage produce by the user. it is programmed by virtual instrument, some sort of interactive games to show students who is able to produce more voltage
Tuck3rz is offline
Old 20th October 2009, 04:15 AM   #9
Man, that got compicated in a hurry.
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 20th October 2009, 04:20 AM   #10
sorry. i m not good explaining in my english this is the flow chart
Tuck3rz is offline
Old 20th October 2009, 04:24 AM   #11
Sounds awesome! Ive been wanting to do something like this But haven't had the money for an inverter or the batteries or the bicycle to mod XD.
I'll gladly try to figure this out with you along the way
Do you have any microcontroller experience? Any electrical experience?
Mike
Old 20th October 2009, 04:28 AM   #12
i m from currently studying electrical engineering
i have learnt micro controller but still figuring out how do it really works
Tuck3rz is offline
Old 20th October 2009, 04:34 AM   #13
Ok, which family of uC's?
P.s. where are you from?
Mike
Old 20th October 2009, 04:38 AM   #14
Most probably 8051
I m from Singapore.
Tuck3rz is offline
Old 26th October 2009, 06:48 AM   #15
hey.. If i use a 28Ah battery, how do i determine the rating of the charge controller?
And if so, would a 24V,8A,1800rpm generator be appropiate
Tuck3rz is offline
generator
Generator eceone General Electronics Chat 7 8th May 2009 02:04 AM
Signal generator patroclus General Electronics Chat 5 9th February 2007 10:12 PM
Ac Generator earjun Electronic Projects Design/Ideas/Reviews 3 25th January 2007 05:16 PM
generator triple_access Electronic Projects Design/Ideas/Reviews 7 27th June 2006 01:58 PM
impulse generator vinodh Electronic Projects Design/Ideas/Reviews 3 12th May 2004 10:56 PM
