Old 19th October 2009, 05:56 PM   #1
Default Any issues with using a 220 VAC power supply on 110 VAC?
I'm building a Jacob's Ladder for Halloween (decent instructions can be found at How To Make A Jacobs Ladder). I got a 15kv power supply cheap but the input is rated at 220VAC 50HZ, 1.2 AMP. Will it cause any problems if I use it on a regular 110 VAC outlet? Will it lower the output voltage?
Deeg is offline
Old 20th October 2009, 06:10 PM   #2
Alternatively, can I use a step-up transformer like the PowerBright VC-300? The 15kv power supply puts out 20mA so if I've done my math right the 300 watt PowerBright has enough power.
Deeg is offline
Old 20th October 2009, 06:25 PM   #3
It will likely work at 110VAC but with reduced output voltage.
The supply is rated at 264W input (1.2A x 220V) so a 300W transformer should work.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 21st October 2009, 06:00 PM   #4
Thanks crutschow. The 15k transformer didn't have enough juice when I plugged it directly into the wall socket but worked great with the VC-300. I'm still somewhat of a newbie at this and I'm always pleasantly surprised when my projects work.
Deeg is offline
Old 21st October 2009, 07:48 PM   #5
Yea, the Jacobs ladder concept runs off of the same thing lightning does. There is a required voltage per linear inch of air that is required to drive the current and create the arc. From a quick e-search I find that the voltage requirement for an arc in air is about 33 kV/cm which is about 83,000 volts per inch of air.
So underpowering it would definately cause it to not produce the propper arc across the air gap.
It sounds like a fun project.
devronious2009 is offline
110, 220, issues, power, supply, vac
Anyone have 12VDC to 120 VAC power supply circuit 89Panadol Electronic Projects Design/Ideas/Reviews 2 10th October 2009 12:23 PM
Convert 24 vac to power 2.5 vdc LEDs ? vinny2cubes General Electronics Chat 23 24th June 2009 03:52 PM
24 vac diode gestern1 Electronic Projects Design/Ideas/Reviews 5 2nd May 2009 08:40 PM
Building a voltage regulator for 220 VAC boatsman General Electronics Chat 3 15th February 2008 05:33 PM
Sinewave Inverter 12 Vdc to 220 Vac Edy_Tse88 Micro Controllers 14 2nd December 2007 03:02 PM
