npn transistor help
  1. #1
    ILikeComputers ILikeComputers is offline
    npn transistor help
    Hi!
    I need a npn switching transistor that runs on a 9v or less circuit. Any ideas on what to get???
  2. #2
    ericgibbs ericgibbs is online now
    Super Moderator
    Quote Originally Posted by ILikeComputers View Post
    Hi!
    Most transistors will work from a 9V supply.
    You must consider the current the switching transistor is going to conduct, collector/emitter, what do you want to control.?
    A good general purpose transistor is the 2N2222.
    0
    "Nigels Asm tutorials:" www.winpicprog.co.uk/
    "Ian Rogers 'C' conversion of Nigels Asm tutorials:" http://www.electro-tech-online.com/c...torials-c.html
  3. #3
    I want to order from here US - Electronic Components Distributor | Newark.com, but I can not find the part. Where else would I be able to order them from???
    0
  4. #4
    electronspeed electronspeed is offline
    Ya off course most of the transistors work on 9V.For knowing the maximum value, you should refer to its data sheet. Some common transistors are BC107,SK100
    0
  5. #5
    audioguru audioguru is offline
    I think the very old BC107 was replaced by the BC547 about 40 years ago and the very old SK100 is available only in India.
    Newark sells the 2N3904 little transistor.
    0
  6. #6
    I searched for the BC107, but the collector voltage is 50v. Would that still work with 9v?
    I just wanted to thank everyone for helping me out(I have not found the right one yet), but I play to buy about 150 of them, I just want to be sure I get the right kind. :-)
    0
  7. #7
  8. #8
    The max allowed collector to emitter voltage of the old BC107 with the base shorted to the emitter is 50V. If the base is not connected then the max allowed collector to emitter voltage is 45V.
    Any transistor will work with a 9V supply.
    Please post your schematic so we can see if a little transistor will survive the current.
    0
  9. #9
    Thanks that would work!
    0
NPN transistor Gregory Datasheets, Manuals or Parts 2 11th June 2009, 01:09 AM
npn c945 transistor T-bro General Electronics Chat 5 17th May 2009, 08:26 PM
Equivelent NPN Transistor Gregory Datasheets, Manuals or Parts 4 24th April 2009, 05:44 AM
NPN transistor Bartx7000 General Electronics Chat 5 30th January 2003, 04:35 PM
NPN Transistor Bartx7000 Datasheets, Manuals or Parts 5 26th January 2003, 01:50 PM
Page Time: 0.05846 seconds      Memory: 7,197 KB      Queries: 16      Templates: 0
