The RAM chip is a 2114N-2L 1Kx4 SRAM chip. Its address pins are connected to the 5v output of the 8-bit DIP switch. It's Data bus from the RAM is then connected to a buffer 74LS244 chip. The buffer's input is connected to the 4-bit DIP data, and it outputs its data onto the data bus. The data bus is then connected to a 4-bit D latch which outputs its memory to the four LED's. The write button is connected to a transistor as a NOT gate. The Output of the NOT gate is connected to the RAM's
Write pin (active low), the data buffer's
Output Enable Pin (active low), and to the LED's D-latch
Latch Enable pin (active high).
Ok, hopefully you're still with me here.
The problem is, it sorta doesn't work. I see hints of it working, but it just doesn't work. I can leave the address at 0x00000000, and set the data to 0x0100 for example, and press
Write. The LEDs will then immediatly reflect 0x0100. But then, if I lightly tap the wires on the small address bus, the LEDs start lighting up randomly as eigher all on, all off, the data in the data DIP, or some other memory addresses data.
But wait! That's not all!
Here's the
super duper odd part: The circuit seems to respond to
LIGHT!! If I wave my hand or fingers around the address bus, the LEDs dim, and sometimes change their data as if I was touching the address bus. The same also happens if I tilt the board, or press down on its corners (away from any wires or components).
I can make a video of it if you'd like.
Here's more info about my circuit:
It's based off of Donn Stewart's Z-80 computer at
Home-Built Z-80 Computer
Here are the main schematics on that site that I used:
http://www.cpuville.com/images/Z80/schematic_6.GIF (I only used the top RAM)
http://www.cpuville.com/images/Z80/schematic_7.GIF
Also, I only used 4 bits of data in the data bus. I left the upper four data pins unconnected on the buffer and the LED d-latch.
I also drew myself a little diagram for myself that shows the 3 ICs and how I connected the pins. I can scan that if you'd like.
Well, hopefully you're still there. If you're reading this, here's a cookie for you! (Cookie: °). It's a bit small, but I'll give you a bigger cookie if you're able to help solve this mystery.
Thanks in advanced,
Drew
