+ Reply to Thread
Results 1 to 7 of 7
Thread: Exterior House Lighting.
  1. #1
    xl5
    xl5 is offline
    xl5 Newbie
    Join Date
    Dec 2007
    Location
    Scotland
    Posts
    37
    Default Exterior House Lighting.
    Prior to going on holiday over two weeks ago i decided i would connect a stand alone type pir detector (1Kw handling) to switch my 3 exterior lights [on] at a preset darkness.
    Only when i looked at the instructions on the box/carton it said for incandescent lamps only...The lamps insitu are the D type Fluorescent 16W per lamp, what i would like to know is why i cannot use this stand alone pir to switch Fluorescent types, my immediate thoughts were the momentary lapse in start up voltage from these Fluorescent lamps are the reason!
    NB: Just left the 3 lights on permanent whilst absent on Holiday.
  2. #2
    BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent
    Join Date
    Jun 2009
    Location
    Huntsville, Alabama USA
    Posts
    2,174
    I'm not sure. It may be that the ballast for your flourescent lamps have a large "inrush" current at startup. If that's not the case, then you might be OK to connect your detector. But check w/someone more knowledgable than I before you do that. Otherwise, you mihgt just try a simple timer.
    Lions and tigers and bears, OH MY!
  3. #3
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,788
    Usually they just switch using a relay, electronic ballast low-energy 'bulbs' should be fine.
    I suspect it's old flourescent fittings they are concerned about, the back EMF from the ballast choke makes the contacts arc across.
  4. #4
    4um Addict Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent
    Join Date
    Jan 2009
    Location
    Toledo, Ohio
    Posts
    838
    Because some florescent ballasts need the sin wave to be fairly pure for their electronics package, anything coming out of a Triac is not so smooth.
    Mike 2545
  5. #5
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    TRIAC controllers in these devices typically trigger near zero crossing. CFLs (and fluorescent fixtures) draw almost no current at zero cross because the voltage is too low to make the lamp conduct.
    So the TRIAC gate is triggered at zero cross, but turns off (or sometimes never turns on) due to lack of holding current. Later in each cycle of mains voltage, the lamp is ready to accept current. But the TRIAC gate is no longer being driven.
    It gets worse. Sometimes the TRIAC triggers and holds. This is on random cycles, and is really bad for the lamp (and controller).
    de KI6RWX
  6. #6
    Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent
    Join Date
    Jul 2008
    Location
    Out there
    Posts
    1,757
    It's because the PIR turns the light on for a very short time while someone walks down the path.
    Incandescents should be used because they come to full brightness in a second. Those silly CFL things turn on very slow and are quite dark for some time before they come to full brightness and someone might trip off the path and break their neck.
    So their lawyer states you MUST use incandescents.
    (it will work fine with CFLs too if you don't mind the crappy light-up time)
  7. #7
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    Maybe I went into too much detail and nobody finished reading.
    Before posting my reply I actually hooked a couple different CFLs to a TRIAC-based PIR. I looked at the waveforms. I have a Leviton PR180 which will not drive a variety of standard CFLs.
    The typical cheap CFL presents a load which a TRIAC cannot drive.
    de KI6RWX
+ Reply to Thread
  1. doll house lighting (simple - newbie)
    By ckoral in forum General Electronics Chat
    Latest: 2nd January 2009, 10:58 PM
  2. House Alarm
    By slickonez99 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th December 2008, 03:39 AM
  3. Buying My First House
    By jrz126 in forum Chit-Chat
    Latest: 19th November 2008, 03:12 PM
  4. Help On Car Interior and Exterior LED Lighting Project
    By chromebeast in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th February 2004, 06:04 PM
Tags for this Thread
