Old 30th June 2004, 08:58 PM   (permalink)
Default Simple Remote Control Theory??
Hi everyone
What is the basic theory of remote control??
This is what I think it works:
The transmitter: A 555-timer to send out the pulsating signal with LEDs.
The reciever: A voltage devider, with one resistor being a LDR, connected to a de-coupling capacitor, then it is connected to a constant biasing-voltage divider, then connected to a transistor( BJT CLASS A CE) amplifier.
Next its connected to another de-coupling capacitor, then it passes through a PASSIVE RC x-ORDER BAND-PASS filter( x being any number).
Then it is de-coupled again, biased again and then amplified(CE) again.
Then, by my theory, I will have a "remote-control" fundamental circuit, ready to be used with a shcmit-trigger,etc.
SO, WILL IT WORK???
I am currently researching transistors in-depth(going through all the info I can), and I wish not to use OP-AMPS( I have only vague knowledge of OP-amps), and I have no knowledge of photodiodes and photo-transistors.
Thanx for reading this post.
CHEERS
Beware, you who seek first and final principles, for you are
trampling the garden of an angry God and he awaits you just beyond the last theorem.
HANDzCLEANx is offline
Old 1st July 2004, 06:11 AM   (permalink)
Default Re: Simple Remote Control Theory??
Originally Posted by HANDzCLEANx
Hi everyone
SO, WILL IT WORK???
CHEERS
If you look at my IR PIC tutorial that explains a bit more about it, but basically IR remote control works by using a carrier of about 38-40KHz. This is then pulsed on and off by the digital data in the transmitter, the receivers use an IC which does all the hard work and gives out a logic level signal based on the original digital data transmitted. You then have to decode the digital data to do what you want, it's usual to use a micro-controller at either end, or a specific custom device - which is simply a pre-programmed micro-controller.
