+ Reply to Thread
Results 1 to 2 of 2
Thread: Need help choosing gyro and accelerometer
  1. #1
    chris414 Good chris414 Good chris414 Good
    Join Date
    Apr 2009
    Posts
    113
    Default Need help choosing gyro and accelerometer
    I'm building an imitation segway, much like this guy did: Building a Balancing Scooter. I dont have any experience with gyros or accelerometers, so was hoping for some advice before i waste my money on something that's not going to work
    For the gyro:
    Looking at the gyros by Analogue Devices on this page: Gyroscopes | MEMS | Analog Devices
    What range should I be looking at? I was thinking of using 50 deg/s for when measuring more fine movements ie. when the thing just needs to stay balanced and upright, and using a 150 deg/s for sudden changes of alignment... would that be alright?
    For the accelerometer:
    I've read that for balancing robots using gyros, it's best to use two accelerometers mounted perpendicular to one another to find where the absolute "up" direction is (tho once you're moving you can't use the accelerometer anymore so you integrate the angular rate from the gyro to determine position). What accelerometer should I be looking at? A range of 2g should be fine shouldn't it? after all i'm only trying to find the direction of gravity... I was thinking the ADXL203 from this page Low g Accelerometers | MEMS | Analog Devices.
    Thanks for the help!
  2. #2
    Join Date
    Apr 2009
    Posts
    113
    bump... anyone?
+ Reply to Thread
  1. Need help choosing gyro and accelerometer
    By chris414 in forum Robotics Chat
    Latest: 4th October 2009, 09:05 AM
  2. Off competition project - gyro-soup-heater
    By Boncuk in forum General Electronics Chat
    Latest: 13th July 2008, 01:34 PM
  3. Balancing robot gets gyro
    By futz in forum Micro Controllers
    Latest: 22nd May 2008, 05:35 PM
  4. Gyro degrees/second
    Latest: 8th May 2008, 05:23 AM
  5. 3 Axis DC/DC Gyro
    By padu in forum Datasheet/Parts Requests
    Latest: 5th June 2006, 07:24 PM
Tags for this Thread
