| | #31 |
MRAl VERY, VERY , VERY, GOOD explanations. | |
| | #32 |
| | #33 | ||
Now, as for, Quote:
| | #34 |
Ok, what about this simple one? Can we find the final voltage of the capacitor after the Switch of 180 ohms Resistor is closed. Last edited by Electronman; 24th October 2009 at 01:30 AM. | |
| | #35 |
Can somebody suggest me how to solve the above circuit? It is not a simple RC circuit at some times (when we close the SW of 180Ohms resistor) Last edited by Electronman; 24th October 2009 at 01:38 AM. | |
| | #36 |
Hi, Are you saying that the first lower switch is closed already and then you close the upper switch and you want to know the voltage across the capacitor after a very long time has passed? If so, it is just the voltage across the resistor as long as both switches stay closed. Just to note, it helps if you label the switches too so we can refer to them as SW1, SW2, etc. Last edited by MrAl; 24th October 2009 at 08:08 AM. | |
| | #37 | |
Can we find any time constant for the cap and see whenit reachs to voltage of 180R? besides what about when the cap is charging but not full charged then how can I calculate the time constant for this circuit? Thanks | ||
| | #38 |
Hello again, The time constant of this circuit isnt too hard to calculate, but you have to realize that the more complicated the circuit gets the harder it starts to become to calculate the time constant and you eventually have to resort to more sophisticated circuit analysis techniques that you would have to learn. Some of the techniques are not that difficult however but they do take a little while to learn. As you know, for a single resistor and capacitor R and C the time constant is simply R*C. For this simple circuit the time constant can still be calculated by multiplying R times C, but before that we have to calculate what R is. For this circuit, R is simply the parallel combination of R1 and R2: R=R1*R2/(R1+R2) and so again the time constant is: R*C. As you also know the voltage across the capacitor in a single RC circuit is: Vc=Vs*(1-e^(-t/RC)) but there is another thing to think about with the two resistor circuit, and that is the source voltage level Vs. With a single R and C we usually take the voltage to be the full battery voltage, but for this circuit because there is a divider we also have to calculate a new voltage value. Since we want the voltage across the capacitor, we first calculate the divider voltage Vd: Vd=Vbatt*R1/(R1+R2) so Vd=12*180/(180+400) and now we have the right voltage to use for the equation: Vc=Vd*(1-e^(-t/RC)) with R calculated above as the parallel combination of R1 and R2. Note that Vc is now the voltage across the capacitor, with the reference node being the junction of R1 and R2. Thus if we used a meter to try to see this change we would put the black lead on the junction of R1 and R2 and the red lead on the +12v power supply positive terminal. If you want to calculate the voltage at the node junction of R1 and R2 with reference to ground, then you would change Vd to be the voltage across the 400 ohm resistor due to the voltage divider instead of across the 180 ohm resistor. Note the above analysis is for when both switches are turned on at the same time. If you want to calculate what happens when switch 1 is turned on first and switch 2 is turned on later, you have to first calculate the single RC circuit and then add the second resistor later when switch 2 is turned on. When switch 1 is turned on the cap starts to charge up with full battery voltage until it reaches the full 12v. Later when switch 2 is turned on the cap starts to discharge until it reaches the final value determined by the voltage divider. The first part is easy because it's just a single RC circuit, but with the second part (switch 2 turned on) you would have to calculate the difference between the 12v supply and the R1,R2 node (voltage across C1) and so Vd would come out to the difference between 12 and the voltage divider 3.72v (final value of node R1,R2) and so the cap voltage then would be: Vc=12-(12-3.72)*(1-e^(-t/RC)) where again R is the parallel combination of R1 and R2 and the time constant again is R*C. The above assumes that the capacitor C1 has been allowed to charge to the full voltage of 12v before the second switch was closed. If the capacitor was not allowed to charge for at least 5 time constants or so, then the initial cap voltage is not 12v when switch 2 is closed so we have to modify the formula to account for this by changing the 12v to whatever the cap voltage was just before switch 2 is closed: Vc=Vc0-(Vc0-3.72)*(1-e^(-t/RC)) so if the initial cap voltage is 6v then: Vc=6-(6-3.72)*(1-e^(-t/RC)) Some simplification of this last formula might be possible also. Last edited by MrAl; 24th October 2009 at 11:23 PM. | |
| | #39 | |
Hello And thanks a bunch for your very very helpful posts. Very complete explanation thanks for it too, but one thing that I am not able to understand is Why there is a PARALLEL combination of R1 and R2 in this circuit? I am not able to see any though!? | ||
| | #40 |
Hello again, That's a good question and one that is a little hard to understand at first, but a simple application of superposition helps to explain a little bit. One way to fully analyze this circuit is to use superposition where the two sources to be 'killed' are actually one and the same source, the 12v supply. That's what we will attempt now... The first step would be to realize that the 12v source feeds BOTH the resistor R1 and the capacitor C1. Simply put, they both connect to that 12v supply. To make this circuit simpler to analyze, we can use superposition by performing a few simple manipulations on the circuit to allow the individual analysis of two parts of the circuit (which are simpler than the whole) and then add the results together to get the final analysis. This means there will be two steps where we manipulate the circuit and one final extra step where we simply add the two results together: [1] Disconnect the left side of C1 and short it to ground (which BTW puts it in parallel with R2) and take the response at the R1,R2 node. This gives us a voltage we will call simply Va. So far though the analysis is incomplete, but we have simplifed the circuit a little. [2] Reconnect the capacitor as it was before to the 12v supply, then disconnect the left side of R1 and short that lead of R1 to ground instead of to the 12v supply. Note that doing this puts R1 in parallel with R2, which is the key to this question of how R1 gets in parallel to R2. Then, find the response at the R2,C1 node (same node as before but now the left side of R1 is shorted to ground). We'll call this new voltage response Vb. [3] (final step) The only thing left to do now is to add Va plus Vb, and that gives us the total response, but note that in order to get Vb we had to put R1 in parallel with R2. Another way to find out how R1 gets in parallel with R2 is to do a full analysis of the circuit and look at the time constant in the resulting formula. It's the denominator D of the exponent of e^(-t/D) which results. From that we can get the value of the equivalent resistor R in the exponential part of the formula which written out that way comes out to e^(-t/RC). If we did this numerically we could simply divide the denominator by the capacitance C, but if we did this algebraically we would actually end up with R*C in the denominator, and R would come out equal to the parallel combination of R1 and R2. I know this sounds a little strange at first, but after you do a few problems like this on paper it starts to make a lot of sense. If instead of using superposition we could do a full analysis like this... First, transform all the elements into their impedance equivalents: R1=>R1 R2=>R2 zC1=1/(s*C1) Next, calculate the parallel combination of R1 and zC1 and call this new impedance Zu: Zu=R1/(s*C1*R1+1) Next, calculate the voltage divider effect of combined impedance Zu and R2: V=E*R2/(Zu+R2); which comes out to: V=E*(s*C1*R1*R2+R2)/(s*C1*R1*R2+R2+R1) Now we want the step response so multiply that by 1/s: V=(1/s)*E*(s*C1*R1*R2+R2)/(s*C1*R1*R2+R2+R1) which comes out to: V=E*(s*C1*R1*R2+R2)/(s^2*C1*R1*R2+s*R2+s*R1) Now transform to the time domain using the inverse Laplace transform, and we get: V=E*(R1*e^(-t*(R2+R1)/(C1*R1*R2)))/(R2+R1)+E*R2/(R2+R1) and now we concentrate on the exponential part: e^(-t*(R2+R1)/(C1*R1*R2)) and note that this is the same as: e^(-t/(R*C1)) where R*C1 is the time constant if we substitute: 1/((R1+R2)/(R2*R1)) with R, and that: 1/((R1+R2)/(R2*R1))=(R1*R2)/(R1+R2) and finally we note that that last result is equal to R: R=(R1*R2)/(R1+R2) which is again the parallel combination of R1 and R2. Thus, R*C1 is the time constant of the circuit and R equals the parallel combination of R1 and R2. Last edited by MrAl; 28th October 2009 at 02:50 AM. | |
| | #41 |
Thanks a lot sir, you are a genius, Just another question is why we want to do so? is that due to this fact that the capacitor has a charge voltage and then a discharge voltage or based upon having 2 power sources in the circuit..?? Please tell me if we have to use superposition law for all firs order circuits base up on capacitors ( due to existance 2 sources: a, power supply and b, the capacitor itself)? Thanks a bunch | |
| | #42 |
Superposition is for when we have 2 or more power sources, why could you use it here in this circuit too?
| | #43 |
Hi again, We are not forced to use superposition, but for the question of how R1 gets in parallel with R2 to form the time constant R*C1 can be visualized a little easier when looking at what happens when we do use superposition. See the attached drawing for a graphical view on this and note the last circuit how R1 and R2 ended up in parallel. You can use superposition for any circuit like this really. It's a more general principle that pertains to linear circuits. Here's the drawing: | |
| | #44 |
Oh, now I understand what you are talking about, you have used the source transfer or something so to make the single sourece to be converted in to 2 and then use superposition law. good job. sorry but 2 other questions. Suppose the SW2 (the above switch) is open for hours, and I turn the left SW on (while the capacitor has no charge) and want to calculate the time constant for the capacitor for while the 9V is across it ( 6V is across the R2), Then I am not able to use the the formula (t=RC) so I have to use the first order formula I,e Vc=Vb(1-e^(-T/RC)) so: 9=15(1-e^(-T/(400x1000uF)), If I find "T" then It is my time constant i.e when the capacitor reaches to "9V" right? 1: How to convert the above formula so that I could calculate "T"? I know that I have to use "Ln" but can you let me the right formula to do it so that I do not make mistake (sorry my poor math)? 2: do I need to multiple the calculated "T" by 5 after I calcualte it by the formula I asked you? Last edited by Electronman; 28th October 2009 at 09:18 AM. | |
| | #45 |
Hi again, If you start with a formula like: Vc=Vs*(1-e^(-t/RC)) and you want to solve for t, you have to manipulate the formula a bit using algebra and logarithms. Starting with: Vc=Vs*(1-e^(-t/RC)) we can first distribute the Vs to get: Vc=(Vs*1-Vs*e^(-t/RC)) then simplify and drop the outer parens and we get: Vc=Vs-Vs*e^(-t/RC) and then subtract Vs from both sides and we get: Vc-Vs=-Vs*e^(-t/RC) and then divide both sides by Vs and we get: (Vc-Vs)/Vs=-e^(-t/RC) and then multiply both sides by -1 and we get: (Vs-Vc)/Vs=e^(-t/RC) and now that we have the exponential part isolated we can take the natural log of both sides and we get: ln((Vs-Vc)/Vs)=(-t/RC) drop the right side outer parens and we get: ln((Vs-Vc)/Vs)=-t/RC multiply both sides by -1 and we get: -ln((Vs-Vc)/Vs)=t/RC and finally multiply both sides by RC and we get: -RC*ln((Vs-Vc)/Vs)=t and swap sides to get the final formula: t=-RC*ln((Vs-Vc)/Vs) So now knowing R,C,Vc and Vs, we can calculate t instead of calculating Vc as before. When you calculate t in this way you do not need to multiply that t by 5 because that is the actual t that would cause the voltage Vc. Last edited by MrAl; 28th October 2009 at 01:01 PM. | |
