| I'm looking for information on different IC packages. One circuit I want to play with uses a Fairchild FAN5611...but it comes in a SC-70 package. I'm not very familiar with the SC-70, but it certainly looks like it is too small to solder to, given my limited soldering abilities. So, question #1, where can I find a listing of packages and their sizes and uses? I assume some packages simply aren't used by DIY hobbyists because of their difficulty to work with. Second question, exactly what do you use to work with each type of package? Do you have a source for socket adapters and that sort of thing so that you can easily make connections to various sized IC packages? | |
| Some companies make up names for ic packages, like for example maxim wich calls a TSOP package micromax, for names made up by a company themselves you should check the companies website or the device's datasheet.. now for some standard ones http://www.adapters.com/Packages/ For you second question, I try to use DIP (the normal large package) on experiment boards. If a device isn't available in DIP then i make a adapter PCB to convert the pinout to DIP spacing... When a project is complete and I make a PCB for it I try to use as much smd devices as possible, so I don't have to drill much holes :lol: | |
| Thanks to both of you. Exo's package listing is quite helpful for the first question. ChrisP's link shows me that I can't solder to that tiny thing. I guess I'll just have to find a different IC to do the job? | |
| Well, you do need a pcb, if you want to build it on veroboard then you can't... But if you can make a PCB then soldering it won't be too hard, it's only slightly smaller then SOT23... | |
