+ Reply to Thread
Results 1 to 6 of 6
Thread: Need help measuring noise power
  1. #1
    speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent
    Join Date
    May 2007
    Location
    USA
    Posts
    1,414
    Default Need help measuring noise power
    Hi guys,
    I have to measure a DC/DC converter at work and make sure it's noise power is under a certain spec. Bandwidth is 10Khz to 2Mhz, and it has to be something like -100dBm/Hz. Is there a simple way of doing this with a scope or a piece of test gear my company could rent to check this? Any help would be appreciated. Thanks!
  2. #2
    bountyhunter Excellent bountyhunter Excellent bountyhunter Excellent bountyhunter Excellent
    Join Date
    Jul 2009
    Posts
    726
    You need to find out what EMI spec they are trying to meet. The spec gives a plot of noise EMI versus frequency that the system has to stay below. The envelope of allowable noise gradually gets lower as frequency goes up. I have done EMI compliance a few times on our power supplies, we always hired specialists because the equipment is very specialized and expensive.
  3. #3
    Warpspeed Newbie
    Join Date
    Sep 2009
    Location
    Melbourne, Australia
    Posts
    92
    Agree with Bounty Hunter.
    You need to get a copy of the specification that needs to be met.
    More often than not it will include details of exactly how the measurement is to be performed.
    There are a variety of ways to define and measure noise depending upon the application, and applications vary hugely.
  4. #4
    Join Date
    Jul 2009
    Posts
    726
    There are specific specs called out which will define the test methods. We had specs like MIL-STD-883 and others, and they give the specific test setup to take the data. You always have to get it straight with the customer exactly what they are requiring.
  5. #5
    RCinFLA Good RCinFLA Good
    Join Date
    Jul 2009
    Location
    FLA, USA
    Posts
    325
    The piece of equipment you will need is a spectrum analyzer.
    You will likely need at least a 1 GHz analyzer but depending on what spec you are required to meet it might extend higher since there are a lot of mobile phones operating in 2 Ghz frequency range.
    There are radiated specs, requiring an antenna site to verify, and conducted specs where power cables and other cables are directly connected to spectrum analyzer.
    There are service agencies that will make the measurements for you and certify the results.
  6. #6
    Warpspeed Newbie
    Join Date
    Sep 2009
    Location
    Posts
    92
    Maybe not if the noise measurement is conducted noise into the dc power source and the dc load, and not radiated (into the surroundings) radio frequency noise.
    This is why the specification is so very important. Without the specification, there is no real way of knowing what is actually to be measured, or how to go about measuring it.
+ Reply to Thread
  1. measuring power of solar panels
    By Thunderchild in forum Renewable Energy
    Latest: 15th September 2009, 12:26 AM
  2. Power Measuring Methods
    By Suds in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th March 2008, 04:53 AM
  3. measuring output Power
    By walters in forum General Electronics Chat
    Latest: 10th June 2005, 04:11 AM
  4. Measuring noise with O'scope
    By Optikon in forum General Electronics Chat
    Latest: 8th January 2005, 10:25 PM
  5. help me to design a noise measuring device
    By anandtshinde in forum Electronic Projects Design/Ideas/Reviews
    Latest: 29th December 2003, 10:38 AM
Tags for this Thread
