+ Reply to Thread
Results 1 to 12 of 12
Thread: Analogue Voltmeter
  1. #1
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Default Analogue Voltmeter
    I'm looking for an ancient analogue voltmeter with the needle centered for zero position, to indicate positive and negative voltages.
    Most desirable would be ±5V, but any range up to ±20V will do as well.
    Does anybody know a source of those.
    Thank you
    Boncuk
  2. #2
    The Electrician Good The Electrician Good
    Join Date
    Jan 2009
    Posts
    129
    Search eBay for "panel meter" and you will find items like this:
    Centre Zero 1mA Moving Coil Panel Meter, Milliammeter - eBay (item 150370702849 end time Oct-04-09 11:14:18 PDT)
    With a suitable series resistor, the full scale voltage can be whatever you like.
  3. #3
    House0Fwax Newbie
    Join Date
    Nov 2006
    Location
    Hampshire U.K.
    Posts
    293
    Quote Originally Posted by The Electrician View Post
    I tried 'Centre zero', it narrows it down.
    I also tried 'Center zero' and got exactly the same results.
  4. #4
    Join Date
    Jan 2009
    Posts
    129
    Quote Originally Posted by House0Fwax View Post
    The problem is that there are some zero center meters in the "panel meter" category whose sellers haven't used the words "zero center" in the description, so a search won't find those.
    You will have to just look through all 1587 "panel meter" search hits to find those, and I know there are some in there; I've seen them.
  5. #5
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Thanks for your replies, HouseOFwax and The Electrician,
    I searched for "centered voltmeter" and the result was thousands of analog and digital voltmeters.
    in the meanwhile the customer has decided to use two LED bars instead.
    Boncuk
  6. #6
    Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent
    Join Date
    Feb 2003
    Location
    Harviell MO USA
    Posts
    956
    If is has to be a panel-mounted meter, you may be in for a tough search. If looking for an instrument that will do this, look to several: vacuum tube voltmeters could have their ZERO adjustment set to center value and most had a -|+ mark at center scale to set the pointer to; a transistorized voltmeter should do the same thing; a differential voltmeter not only can have a zero center indication, but you can offset that center by a precise number of volts and swing the pointer on either side of that.
    For that matter, you can buy a nice differential voltmeter and ruin it by ripping the zero center meter out of it for your use. A pox on you if you take this advice.
    R.I.P.
  7. #7
    colin55 Bad colin55 Bad
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    If you get an ordinary 0-1mA movement, you can adjust the hair spring to create a centre-reading pointer.
    Get a $10.00 multimeter from a Chinese $2.00 shop, or from an auto shop.
  8. #8
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Quote Originally Posted by colin55 View Post
    I've tried that already. No way to get the needle centered. (max. 1/3 of the scale)
  9. #9
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    I have done it may times and always got the pointer to centre-scale.
    It just a matter of adjusting the hair-spring. You can desolder the end of the hair spring and reposition it on the pointer.
  10. #10
    flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent
    Join Date
    Oct 2008
    Location
    Amsterdam
    Posts
    558
    If you adjust to center and the meter was not designed for that will it still be linear? Will it be accurate on the low side or high side for that matter? My guess is some will some won't.
    Will your application require the reading of overshoots? Will the meter still be usable for this?
  11. #11
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    You are not affecting the linearity. You are only changing the sensitivity, in that a 1mA movement may now be a 1.1mA movement.
  12. #12
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Thanks for the advise. I better forget about the analogue voltmeter, since the customer has decided to use two LED bar graphs instead.
+ Reply to Thread
  1. need analogue oscilloscope knowlage
    By mashersmasher in forum General Electronics Chat
    Latest: 11th May 2008, 02:16 PM
  2. pic16f887 analogue reference
    By spuffock in forum Micro Controllers
    Latest: 15th October 2007, 04:19 PM
  3. ADC for 2 analogue inputs
    By flemmard in forum Micro Controllers
    Latest: 24th September 2007, 08:23 PM
  4. analogue DC-DC converter
    By demirural in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th January 2006, 11:48 AM
  5. analogue circuit
    By theEgO in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th August 2004, 12:05 PM
Tags for this Thread
