+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 17
Thread: 4013 to drive 300mA - Problem after Q-output
  1. #1
    financecatalyst Newbie
    Join Date
    Apr 2009
    Posts
    4
    Exclamation 4013 to drive 300mA - Problem after Q-output
    Hi
    I have 4013 which toggles the output Q pin upon applying pulse on the clock pin. D and Qbar are joined. Pin 4 - 6 are joined and earthed. It works just fine when no load is on the Q (output pin) and it goes crazy when there is load attached via transistor which is bunch of LED's requiring 300mA. Tansistor used is 9014 directly attached to Q pin to drive 300mA bunch of LED's.
    when load is attached, it has very irregular behaviour when pulse is applied to clock pin.
    Can someone help me please?
    Thanks (alot!)
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,696
    Blog Entries
    5
    Post your schematic.
    Bill
    Smart Kits build Smart People
  3. #3
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,806
    Blog Entries
    13
    Quote Originally Posted by financecatalyst View Post
    Hi
    Thanks (alot!)
    Whats the value of the resistor connected between the 4013 Qpin and the base of the transistor.???
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,812
    If the Q-bar output drives the D-input then they must not be shorted by the direct connection of the base of the transistor. a series resistor must be used.
    A CD4013 has an output current of about only 7mA if its supply is 10V. It can drive a 1k resistor. If the supply voltage is less than 10V then the output current is lower.
    But the transistor has a load of 300mA so it needs a base current of 30mA for it to saturate well. It won't work well with a base current of only 7mA.
  5. #5
    Join Date
    Apr 2009
    Posts
    4
    Exclamation Schematic Attached
    Quote Originally Posted by blueroomelectronics View Post
    Hi thanks for your answers. I have attached the schematics. I want to highlight again that this is driving bunch of LEDs. PROBLEM is irregular switching after the transistor is connected.
    It works and toggles fine when nothing is connected to the Q pin. I have tried it with 1K on the output Q pin as well, still no luck.
  6. #6
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,696
    Blog Entries
    5
    Where's the base resistor?
    Bill
  7. #7
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,812
    With a supply voltage as low as 3V the output of the CD4013 has a current of only 1mA or less which is too low to drive the base of the transistor when the transistor has a load of more than about 15mA. Since the currents are so low a base resistor is not needed.
    The transistor needs a base current of 30mA for a load of 300mA.
  8. #8
    Join Date
    Apr 2009
    Posts
    4
    Exclamation
    Quote Originally Posted by audioguru View Post
    True. But can you give me a very cheap solution to solve this problem? AND also tell me please why is 4013 behaving abnormal under load and toggles its Q pin just fine without any load/
  9. #9
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,696
    Blog Entries
    5
    Very cheap? Transistors & resistors are very cheap. Are you building 1000's?
    Bill
  10. #10
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,444
    Use an N-channel MosFet instead of a bipolar transistor. Use a gate resistor of 100Ω.
  11. #11
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,696
    Blog Entries
    5
    Not many FETs will turn at 3V?
    Bill
  12. #12
    Join Date
    Apr 2009
    Posts
    4
    Exclamation Alternative
    If the current schematic is so much of a problem, CAN SOMEONE ADVISE me of any other way (with schematic please) of toggeling the output by applying a pulse, able to operate 300mA load under 3 - 4.5V supply voltage. I will be greatful.
    Many Thanks
  13. #13
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,444
    That one is perfect for the application:
    V(BR)DSS=30V, RDS(ON)=0.08Ω, ID=3.5A, VGS(th)=0.7V, package SOT23
    ZETEX ZXMN3B14F.
    Boncuk
  14. #14
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,812
    If you look at the datasheet of a CD4013 you will see that the Q output is completely separate from the Q-bar output and you can short it without affecting the operation of the IC unless the power supply voltage is high enough to cause a high short-circuit current.
  15. #15
    creakndale Newbie
    Join Date
    Dec 2007
    Posts
    52
    Have you tried adding a bypass capacitor across the 4013's Vdd (pin 14) to Vss (pin 7)?
    creakndale
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. 12-15v in, 5V 300mA(Isolated)out, power supply?
    By peterjm in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd August 2009, 12:30 AM
  2. 4013 and 4017 output behaviour
    By georgetwo in forum General Electronics Chat
    Latest: 20th August 2009, 06:14 PM
  3. digital output drive current help
    By jllabs in forum General Electronics Chat
    Latest: 8th May 2009, 04:19 PM
  4. 4013 alternating output question
    By numberonekiwi in forum General Electronics Chat
    Latest: 30th December 2008, 07:20 PM
  5. 4013 problem
    By shams-_-m in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd March 2008, 06:49 PM
Tags for this Thread
