+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 32
Thread: Generating 30,000V+ from a 9V battery?
  1. #16
    Burningmace Newbie
    Join Date
    Sep 2009
    Posts
    53
    Sorry I'm being so avoidant. It's a bet between me and a friend. I'm keeping quiet as to the details because he's likely to Google our bet and find this page so he can see how I'm going about it. Silly, I know, but there's pride at stake here!
    The short story is that it doesn't really matter what I want to do with it, but how to actually go about doing it.
  2. #17
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,701
    Blog Entries
    5
    What are the conditions of winning the bet? How do you plan to measure 30kV?
    Bill
    Smart Kits build Smart People
  3. #18
    Burningmace Newbie
    Join Date
    Sep 2009
    Posts
    53
    It's not a bet for who can produce the highest voltage from a 9V battery, so we don't need to measure it.
    Treat this as a hypothetical excercise - if you had to create the biggest voltage you could from a 9V battery (or two), how would you do it?
  4. #19
    birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent
    Join Date
    Feb 2009
    Location
    Montreal, Quebec
    Posts
    1,064
    A simple way would be to hook the battery directly to a step up transformer with a push button in between, the push button would have a nice one shot of flux.
    Mike
    My website: www.ElectroBird.net
  5. #20
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,259
    Blog Entries
    2
    Standard issue ignition coil from a newer vehicle can easily do 30 KV. Just use the 9 volt battery to charge up a HV poly cap to a few hundred volts with a old camera flash circuit.
    The camera flash circuit may need a voltage regulator to keep the 9 volt battery form burning it up. Some old ones would take 9 volts for Short Burst some wont.
    "When in doubt, LIGHT IT ON FIRE AND SEE WHAT COLOR OF SMOKE IT CAN MAKE!" -- tcmtech
  6. #21
    Space Varmint Okay
    Join Date
    Jul 2008
    Location
    Tucker GA...USA
    Posts
    1,409
    Quote Originally Posted by Burningmace View Post
    One microamp or higher should do the trick, as long as I can produce 30kV or so. The higher the voltage, the better.
    Well I forgot to mention that the input voltage of my simple Armstrong oscillator circuit is only 6 volts. So 9 volts in would get you probably 3000 volts out. That's one tenth what you are looking for. You could accomplish the rest by increasing the step up ratio on the transformer and increasing the size of the core (physical & AL permeability) if that's all the current you need.
  7. #22
    Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent
    Join Date
    Jul 2008
    Location
    Out there
    Posts
    1,757
    I'm with tcmtech, do it the same 2-stage way camera flashes and strobe lights work; charge a cap to a couple hundred volts, then dump the cap into a simple pulse transformer.
  8. #23
    speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent speakerguy79 Excellent
    Join Date
    May 2007
    Location
    USA
    Posts
    1,414
    Stun guns run off 9V and easily generate 30kV, unfortunately they usually use a custom transformer in the design that won't be easy to get. It steps up 9V to about 600V and then they have an arc gap and an output transformer to get it to 50kV or so. You can by a Talon Mini stun gun online for $20 to take it apart and see how it works, it's basically like I've described here.
  9. #24
    Burningmace Newbie
    Join Date
    Sep 2009
    Posts
    53
    Quote Originally Posted by speakerguy79 View Post
    Two problems with that:
    1) I'm in the UK, and stun guns are classified as offensive weapons. I can't import them.
    2) Stun guns produce a large voltage to arc, but once they've ionised the air they drop down to about 5000V.
    I'm gonna buy a cheap camera and see how it fares.
  10. #25
    arunb Newbie
    Join Date
    Oct 2006
    Posts
    176
    I think he is trying to make a stun gun of 30KV. I think the loser gets zapped...In any case the project sounds dangerous...
  11. #26
    Burningmace Newbie
    Join Date
    Sep 2009
    Posts
    53
    arunb - If I were trying to build a stun gun, I'd just tell you that I was. Besides, a 30kV stun gun would be lethal if it remained at 30kV. The project is pretty dangerous, but I'm not an idiot - I know how to protect myself from electrocution.
  12. #27
    vedo35 Newbie
    Join Date
    May 2006
    Location
    Nederland
    Posts
    75
    if you can find old scanner take the head. you will see a very thin florecent lamp. you can use that florecent lamp driver. minimum needs 5-6 volts. normally using 12volts. driving bc series(but japan series ones) 2 transsitors and a little hv transformer. i gave also 20 volts working very good. hv jumping from 1 cm distance. if you want you can chance transistors with bd series but you have to chance transformer wires little bit ticker.
  13. #28
    Burningmace Newbie
    Join Date
    Sep 2009
    Posts
    53
    Scanners are expensive and hard to come by these days. Most are scanner-printers. It also seems like I'd have to pull out most of the innards to get it to work. I'd rather build something from scratch or with smaller objects.
    I'm heading to the shop in a bit to pick up a disposable camera.
  14. #29
    House0Fwax Newbie
    Join Date
    Nov 2006
    Location
    Hampshire U.K.
    Posts
    292
    Ask at a place where they develop films, they throw cameras away once they have got the film out.
    Last edited by House0Fwax; 4th September 2009 at 05:07 PM. Reason: Spelling error.
  15. #30
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    When I was a teenager (50+ years ago), I used a toothed gear from a clock turning against a strip from a tin can to interrupt the current between the secondary (used here as the primary) of an output transformer from a vacuum tube radio, and a 1.5V D cell.. The output of the primary (now the secondary) winding produced an arc that was, IIRC, about 1/4" long. It made a kitten jump about a foot straight up.
    I know, cruelty to animals. I wouldn't think of doing that now, but then it was funny.
    I now know that it was a flyback circuit.
    One potential problem with using a transformer to create high voltages is that, unless it is designed for that purpose, may get damaged due to interwinding high voltage breakdown.
    Ron
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. Generating EMP
    By osm3000 in forum General Electronics Chat
    Latest: 7th August 2009, 07:18 PM
  2. Generating EM wave
    By MrJammin in forum General Electronics Chat
    Latest: 3rd July 2007, 03:11 AM
  3. Generating an infrared plane
    By sederberg in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th August 2006, 09:19 PM
  4. Generating Sparks
    By dknguyen in forum General Electronics Chat
    Latest: 8th June 2006, 05:36 AM
  5. Sound generating curcuits
    By mubo in forum General Electronics Chat
    Latest: 11th August 2003, 11:10 PM
Tags for this Thread
