Old 22nd August 2009, 06:52 PM   #1
Default Heathkit IP-27 Power Supply Trouble
Hey Fellows,
I'm fixing up an old Heathkit IP-27 power supply for a friend because it isn't working properly. At first It wasn't working at all, but when I took out the fuse and put it back in, it started working again (but not to its full potential). So It was a little dirty and needed some cleaning. Apparently, when you have a load you shouldn't get any voltage drop and the power supply will compensate for the loss voltage. So the voltage stays the same no matter the load. Unfortunately, this isn't happening and when I put a 100Ω resistor around 5V or so the voltage dropped significantly. My first guess is replacing the electrolytic caps since those don't last very long; but I might be wrong. How can I fix this? Here is the schematic because I couldn't find the whole manual online:
http://www.nostalgickitscentral.com/...chema_ip27.gif
I'd appreciate the help!
Heathkit IP-27 Power Supply Trouble-heathkitip-27powersupply-001.jpg   Heathkit IP-27 Power Supply Trouble-heathkitip-27powersupply-002.jpg   Heathkit IP-27 Power Supply Trouble-heathkitip-27powersupply-003.jpg
ElectroNerdy is offline
Old 23rd August 2009, 12:25 AM   #2
no schematic on that link...........
all "txt speak" has been removed from this post for the benefit of all other forum members who may get confused!!!
sheldonstv is offline
Old 23rd August 2009, 01:17 AM   #3
This one works better..
http://www.nostalgickitscentral.com/...chema_ip20.gif
indulis is offline
Old 23rd August 2009, 01:50 AM   #4
What a beautiful old supply!! With a 70v neon voltage regulator valve too!
Many of those rotary switches carry the entire PSU output current and high resistance contacts on them could be the cause of your symptoms.
After testing/replacing caps you should clean all the pots and rotary contacts with spray cleaner. You can also test the rotary switches with a good ohmeter across the switch contacts since there seems to be room to get in with the multimeter probes.
Voltages are marked on the schematic so you can check the voltages.
Probably just replacing some caps and cleaning/working all the pots and switches should get it up and running.
Mr RB is online now
Old 23rd August 2009, 06:36 PM   #5
Thanks for the correct link and the suggestions. I'm not sure that the caps are bad but they might be. Is there a way to test them? I suppose that if they aren't good, the capacitance rating wouldn't abide to the correct value? So, the voltage drops but it isn't supposed to but the current should, correct? Just making sure...
I noticed that when I had a higher current, the voltage didn't drop as much. Could something be attenuating the current? I guess I should clean everything first and then I'll see what I should do next.
Thanks for the help!
Old 23rd August 2009, 11:00 PM   #6
A discrete design like that could have just about anything blown in it. The elect caps probably are funky. may still be functional at reduced performance.
Ditto on the comment that the contacts in all those rotary switches could be oxidized and flaky.
bountyhunter is offline
Old 24th August 2009, 03:37 PM   #7
Right, I'll go ahead and replace the caps for maximum performance and also clean the contacts.
Standby! I'll let you know how it works after that.
Old 25th August 2009, 01:19 AM   #8
Ok, I cleaned the contacts and polished the outside (to make it look nice and clean... ) and now the analog meter doesn't seem to work. It remains at the same level even when I adjust the output voltage!
Old 25th August 2009, 07:28 AM   #9
I agree with the previous poster in that the rotary switch on the front carries all the current. Put the output under load, measure the voltage across the first smooting cap, C2, 3000uF and see if the voltage drops. Then it is probably dirt on the switch. If the ripple is excessive (you really need a scope for this) then chances are the cap has degraded.
I would then move towards the output and see where things start to misbehave
Bill Naylor
www.electronworks.co.uk
Electronic Kits for Education and Fun
Electronworks is offline
Old 25th August 2009, 07:45 AM   #10
... looking at the first, leftmost, image that was posted.
Does the black capacitor, white stripe, look normal? Is the right endcap of this capacitor convex in shape? .... Is there any sign of swelling, or discoloration?
Can't tell from the picture .... would appreciate a clarification.
Electrolytic capacitors seem to be statistically prevalent as the primary mode of failure on aging or older electronic assemblies.
user_88 is offline
Old 25th August 2009, 10:36 PM   #11
Ok, I'm getting about 4mV of DC ripple on that bulky filtering cap at the bottom left-hand corner on the first picture. Is this ok? What would be a good value?
For that capacitor with the white band, all of them are like that. They seem to be painted on one side. They are rated 1000uF at 50V.
Do you guys see that grey wirewound resistor by the bulky filtering cap? Well that's supposed to be 2.5KΩ but it is actually 3KΩ. I'm thinking of replacing that.
The meter doesn't work, it still says 10V with 5V output. The calibration is kind of funny too, when I spin that screw at the bottom of the meter it goes to zero where it should be, then if I keep going It will go up and then go back to zero.
Old 26th August 2009, 03:33 AM   #12
Check the voltages, they are marked on the schematic in the little ovals. Start closest to the transformer, then work through tht evoltages towards the output.
And first i would check the voltage on the neon and the main zener Z1 which derives the reference voltages for the supply regulation.
Mr RB is online now
Old 28th August 2009, 12:02 AM   #13
Ok, I checked to make sure I was getting the Vbe drop and the transistor at the far right corner in the first pic seemed to be fried. The one above was measuring a 0.4V drop and the bad one below measured 12V! Does anyone know where I can find a substitute transistor in addition to the datasheets for this sucker? I'd appreciate it!
Old 28th August 2009, 03:56 AM   #14
If you tell us what transistor you mean in the schematic, we might be able to guess on a replacement.
Old 28th August 2009, 04:17 AM   #15
I already told you. It is an R256A transistor in the second picture. The two transistors you seen are shaped in the way of a bolt and both are the same transistor type.
heathkit, ip27, power, supply, trouble
conversion of pc supply to high power rating supply kamran sadiq Electronic Projects Design/Ideas/Reviews 3 17th July 2009 08:25 AM
ATX power supply -> lab bench power supply Cobalt60 Electronic Projects Design/Ideas/Reviews 29 6th March 2009 09:09 AM
Linear Power Supply vs Switching Power Supply 2Electrified General Electronics Chat 9 3rd October 2008 07:13 PM
Power Supply Experts!! Need help with KEPCO Labs Power Supply headbuttking2 General Electronics Chat 1 24th October 2006 02:05 AM
Switchmode Power Supply Trouble - Help appreciated HandyMan Electronic Projects Design/Ideas/Reviews 23 3rd October 2004 11:17 PM
