Originally Posted by
ericgibbs
I dont know what type of signals you are coupling thru the opto, but be aware adding a 100nF from the base to 0v will significantly reduce the rise and fall times of the signals.!!
EDIT: As you are using a FET to drive the relays, the heat dissipation in the FET's will be increased, also the switching point/times will be delayed.
IMHO it dosnt require a 100nF on the base of the opto, just dont touch the base.
