I built a laundry in part of my garage. For access, I took down part of the wall between the main house and the garage, and then I built a floor about 12" above the cement garage floor, so that the level is the same as the house. Under the floor, I have all the water supply and and drainage plubming. For the mains supply to the washer and dryer, I have an electrical junction box to connect the new outlets to the existing house wire. So, I began to become concerned about flooding from the water supply running down below the built-up floor. So, I changed the juction box to a water proof one. However, I had to open the sided of the box to install the wire strain reliefs, and that makes the box less than waterproof. So, I carefully applied RTV sealant to the strain reliefs and sealed up the wire entry as best as I can. I believe it's pretty safe now. Does anyone else have any opinion on my electrical waterproofing???? BTW, the box is attached to the floor joists on the built-up floor, so it isn't flat on the cememt floor. In other word, water may run off on it, but it will never become submerged, no matter how much flooding I have.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
As long as it is feed by a GFI that is not so low I would not worry too much. But I am no electrician. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| Not GFI protected. But it is circuit breaker protected.
| | #6 |
| DANGER WILL ROBINSON I do not think much of the idea.
| | #7 | |
Outlets in garages and in laundry rooms should have GFIs. Dan Bentler | ||
| | #8 |
I would be more concerned about the wall between the house and the garage. If I recall correctly, you should have a 2-hour fire rating between a garage and a living space.
__________________ de KI6RWX | |
| | #9 | |
BTW, I ran my idea by an electrician friend of mine, and although he wasn't crazy about it, he said it doesn't violate any building code.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. Last edited by BrownOut; 19th August 2009 at 04:22 AM. | ||
| | #10 | |
I'll double check the code. A 2-hour fire wall is not hard to make. Thanks for keeping fire safety in my front mind.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | ||
| | #11 |
Washer and dryer should each be on it's own separate breaker, GFI not absolutely required, If you want it done perfect, get a national electrical code book, ask an electrician friend to take a look at your work, don't worry to much about water proof, don't pack the box too much, make sure it can drain if it does get water in it, get the wire nuts good and tight. ex master electrician, Kinarfi Last edited by kinarfi; 19th August 2009 at 06:27 AM. | |
| | #12 | |
| electronics |
| Electronics HELP!!! | shay87 | Electronic Projects Design/Ideas/Reviews | 1 | 18th May 2009 11:40 AM |
| electronics | sonic seven | Electronic Projects Design/Ideas/Reviews | 7 | 7th May 2009 04:02 AM |
| I am new to electronics, should i carry on with my hobby?(electronics) | amando96 | General Electronics Chat | 17 | 21st January 2009 02:37 AM |
| I know nothing about electronics--HELP | psychobob | General Electronics Chat | 1 | 5th November 2008 04:50 AM |
| New to electronics.... | aaronjk0406 | Electronic Projects Design/Ideas/Reviews | 3 | 23rd February 2008 04:10 AM |
