Old 18th August 2009, 09:42 PM   #1
Default problem with LM324N opamp
hi
im trying to perform a voltage comparator circuit using lm324n opamp
and got these test results at the point that opamp begins to reflect to inputs
#1: Vcc=5 V+=3.2 V-=4.2
#2: Vcc=5.7 V+=4.2 V-=5.7
#3 Vcc=5.6 V+=4 V-=5.7
why the opamp is so sensitive to Vcc
also this circuit was supposed to be a comparator so why would it respond to the input which is 1.5 volts lower than V-
sina-VIP is offline
Old 18th August 2009, 10:02 PM   #2
It's not the op amp that's sensitive to Vcc. It's the trip point as determined by the pot, since it's also connected to Vcc. If you want the trip point to be stable with a Vcc change you need a stable reference voltage for the pot.
Don't understand your V+ and V- voltages. What do they refer to? Are they the trip voltages?
What trip voltage is the pot set to?
The LM324 will only work properly when both input voltages are less the 1.5V below Vcc or 3.5V for Vcc = 5V. (Maximum input common-mode voltage from the data sheet).
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 19th August 2009, 02:47 AM   #3
All your circuits have the inputs too close to the positive supply voltage. Then the PNP darlington transistors at the inputs are cutoff and don't work.
audioguru is offline
lm324n, opamp, problem
Problem with opamp and instrumentation amplifier wizardgrt Electronic Projects Design/Ideas/Reviews 4 10th August 2009 07:39 PM
Opamp problem bigfish256 General Electronics Chat 9 14th February 2009 01:32 AM
How can I use opamp or any component for my problem ? karekok General Electronics Chat 33 20th September 2007 09:22 AM
Opamp problem--I think Torben Electronic Projects Design/Ideas/Reviews 14 23rd February 2007 02:31 AM
Help for opamp to adc kimmi General Electronics Chat 10 6th September 2006 01:37 AM
