If I have a 12V lead-acid battery, hooked up to a DC inverter, how do I calculate how long the battery will last? In the scenario im thinking of, it would be a 12V 24Ah lead-acid battery, and a 400W inverter. I know on the output it would be 120V @ 3.6Amps to get the 400W. Are inverters of this power only intended to be used in a car while its running?(so the alternator is doing the work) | |
If you are very fortunate, the inverter will be 75-80% efficient (including losses in your cable if you minimize them). If the engine is not running, the battery voltage will only be 12V. For 400W out, then you'll need 500-533W in. At 12V, that's almost 45 amperes. If your 24AH battery could be 100% efficient, that would be only 30 minutes. However at 2C (twice the Ampere-Hour number) it probably will only give half of that time (e.g. 15 minutes) before either going flat or exploding. It will last longer if you don't actually use the full 400W from the inverter. If the motor is running, the good news is the input voltage is about 13.8 volts, the current is only 39A, and if the charging system can keep up, everything is happy.
__________________ de KI6RWX Last edited by mneary; 18th August 2009 at 08:06 AM. | |
ok, so i did have it properly(in my head) then. if the adapter was 100%(impossible) then it would be 400W draw from the battery at 12V, which makes it 400/12 = 33Amp draw. also, being that it wouldnt be a deep cycle battery, the battery would be toast pretty soon. just to add something here, any idea what the maximum draw on a non deep cycle, lead acid, battery would be? if it was kept at ideal temps. and without shortening its life. Last edited by Berserk87; 18th August 2009 at 08:11 AM. | |
No idea. Time to do some research. Maybe some of the manufacturers publish specs.
__________________ de KI6RWX | |
Your 24Ah battery will aos probably not be 24Ah when 40A is drawn. I reckon the battery will last for less than 20miniutes.
| | #6 | |
To power portable electronics and lighting, I use "deep cycle" type batteries. The only time I would use a "car" battery for this is if the car battery is so far gone that it is not cranking properly. Then, what have you got to lose?
__________________ Mike ML. | ||
| | #7 |
Most inverters have a 'drop out' voltage, some are set at 11.5 volts. What that means is that the inverter will shut off when battery voltage reaches (drops) 11.5 volts.
__________________ gerty | |
| | #8 |
Depends on the quality of the car battery. I have several old Sears Die hard batteries that are 8 - 10 years old and were severely abused during their life time and they still have good cranking power and cranking time. My dad buys the cheap low end Wal-Mart batteries and most of them dont even make it a year or two in good conditions. As far as draining a battery there seems to be a unrealistic concern about the amps draw blowing them up around here. I have yet to ever have a Lead acid battery explode from either high amperage drains or fast recharging and I have done that to countless numbers of batteries. Yes there are idealistic what if scenarios but then what if everything else happened too! ![]() In hobby electronics 40+ amps is a big number. In the industrial electronics I typically work with 40 amps is not even worth worrying about. Use the proper size wire, fuses, connectors, dont over drain your battery and you will be fine. And over all if you buy cheap junk you get what you payed for in the end!
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | |
| | #9 |
The inverter was just an idea that i was curious about. In reality im not going to be drawing any more than 2-3Amps. | |
| | #10 |
| Its not how many Amps you draw; its how many Amp-Hours (Ah) you draw!
| | #11 | |
![]() i thought if i had a 24Ah battery, i would be able to draw 1Amp for 24 hours =S Last edited by Berserk87; 19th August 2009 at 04:42 AM. | ||
| | #12 |
Yes, that is correct. However, if you draw 24Ah out of a 24Ah battery, you have used its entire capacity. That is ok if it is a battery rated for repeated deep-cycle discharge. If it is not specifically rated for deep cycle use, it is a starting battery. Starting batteries are ruined by just one deep-cycle discharge. They will never regain their rated capacity after one or two deep discharges...
| | #13 | |
the issue here being that deep cycle batterys cost a ton :\ | ||
| | #14 | |
It is ok to repeatedly draw out/put back about the top 15% of the capacity of a starting battery. After all, that is the use model in a car. A normal car battery is typically ~50 to 80Ah, so you could cycle ~9Ah in/out. Most Sealed Lead Acid (SLA, VRLA, AGM) batteries are rated for deep discharge, but not typical flooded-cell car starting batteries.
| | #15 |
blah. whats the cheapest deep cycle battery then, and where can i get it? | |
| 12v, battery, inverter, life |
| Battery life computation | dpj | Electronic Projects Design/Ideas/Reviews | 4 | 28th July 2009 10:25 PM |
| Battery Life Calculation | vne147 | General Electronics Chat | 4 | 30th October 2008 08:07 PM |
| Battery Life | fingaz | General Electronics Chat | 13 | 22nd February 2008 10:40 PM |
| Battery Life Prediction | bitem2k | General Electronics Chat | 8 | 19th May 2007 01:42 AM |
| Battery Life | Gene | General Electronics Chat | 8 | 7th March 2003 02:21 PM |
