If I want to drive a generic N channel FET, say an Infineon IPB70N10SL-16. This is a 100V, 70 amp, 16mOhm RDSonn part. If I use it as a high side switch to a 12 volt source, I know that I need my gate voltage to be higher than the 12 volt rail, but what I don't know is how to calculate/find how much current I'll need to drive the gate. Any help is appreciated.
Is speed important? What's this for? You could bootstrap it but the duty cycle can never be 100%.
Speed is not important. I'll be using it to control a 12 volt solenoid. How do you calculate what the max duty cycle would be? | |
Duty cycle of a solenoid?
Max duty cycle is probably going to need to be about 85%
| | #6 |
| How did you arrive at that number?
| | #7 |
Right now it is a rough estimate. We anticipate that with an 85% duty cycle we should be able to open the solenoid up more than what we think will be needed to get the max oil flow that we'll ever need.
| | #8 |
Solenoids are more of an all on or all off affair. Do you have a model number?
| | #9 |
Unfortunately, I don't actually have any model number in front of me right now. In response to a solenoid being "all on or all off", I want to regulate oil flow and turning the solenoid all on or all off would be like flipping a switch, all or nothing. I want to regulate oil flow more precisely than that.
| | #10 |
Then a solenoid isn't going to do it, PWM on a relay or solenoid is handy for reducing power required to operate it as the holding current is lower than the pull in current.
| | #11 |
The amount of current needed is the Qg / switching time. Your mosfet has a 160nC gate charge. If you wanted a 1us turn on, then your gate current needs to be... 160nC / 1000ns = 0.16A. Obviously, if you want it to turn on faster, you'll need to push more current. Last edited by smanches; 17th August 2009 at 09:47 PM. | |
| | #12 |
Smanches, That's what I was looking for. Thanks a lot!
| | #13 | |
ie: 1/4, 1/2, 3/4, or full, or isn't that accurate enough? PatM
__________________ http://malfam.googlepages.com/ | ||
| | #14 |
Just PWM it like I think you're trying to do. I've done this exact same thing to implement a soft turn-off for hydrolic systems so the rams don't slam when it's shut off. You need to find the inductance of the coil though. Last edited by smanches; 17th August 2009 at 10:56 PM. | |
| | #15 |
But you still won't be able to control the flow rate. It'll be either on or off.
| channel, driving, fet |
| TO-92 equivlants for P-channel IRF9530 N-channel IRFZ44N/IRF530 | carlson | Datasheet/Parts Requests | 13 | 24th April 2009 08:42 AM |
| shot-channel MOS vs. long-channel MOS. | alphadog | Electronic Theory | 9 | 25th March 2009 10:28 AM |
| Driving an N channel Mosfet in a H Bridge on higher side | Dummy123 | General Electronics Chat | 6 | 17th March 2008 03:10 AM |
| pic driving shift register driving leds | Ashlume | Electronic Projects Design/Ideas/Reviews | 3 | 1st May 2007 07:10 PM |
