Old 18th August 2009, 02:11 AM   #16
Originally Posted by blueroomelectronics View Post
But you still won't be able to control the flow rate. It'll be either on or off.
No, but if he turns the solenoid on for 15 seconds and then off for 45 seconds, it will deliver 25% of the flow rate compared to if were left on. As long as the cycle rate is low, this is a valid way of controlling the average flow rate.
Mike ML.
MikeMl is offline
Old 18th August 2009, 02:28 AM   #17
Depends on what system he is working on. For example, if it is just going into a resevoir or something like that. Then hey no prob. Now if it is in an application where a constant stream is needed, just at a lower rate, then problems.
As a chemist, we encounter this situation frequently. Some reactions respond fine to say addition of 10 mL of a reagent every 15 minutes (for a total of 45 min). Other reactions may require the same amount of reagent over the same amount of time, but the reagent has to be added drop-wise, otherwise bad stuff can happen (no product, rapid boiling and in extreme cases explosions).
PedroDaGr8 is offline
Old 19th August 2009, 04:26 AM   #18
I've actually done it before (PWMed a solenoid) and it works rather well to regulate oil flow. I just don't want it BANG!!! on or BANG!!! off but would rather ramp it up and down in a nice controlled manner like Smanches described.
bigfarmerdave is offline
channel, driving, fet
TO-92 equivlants for P-channel IRF9530 N-channel IRFZ44N/IRF530 carlson Datasheet/Parts Requests 13 24th April 2009 08:42 AM
shot-channel MOS vs. long-channel MOS. alphadog Electronic Theory 9 25th March 2009 10:28 AM
Driving an N channel Mosfet in a H Bridge on higher side Dummy123 General Electronics Chat 6 17th March 2008 03:10 AM
pic driving shift register driving leds Ashlume Electronic Projects Design/Ideas/Reviews 3 1st May 2007 07:10 PM
