Is there a software that would automate conversion of integrated circuit to discrete circuit? For example if I have some old, more or less simple in terms of functionality IC that is not manufactured anymore and I want to make a replacement for it, the program would let me type in the functions and properties of IC and then it would generate discrete pcb layout. Is there program like this? | |
No, it's not possible, not without taking the die out of its package and looking at it through a scanning electron microscope anyway.
Sometimes an IC's datasheet will include a functional schematic showing what the equivalent circuit is, but I have the feeling that these schematics are somewhat idealized and would require extra work to make them actually work if you were to try to implement them with discrete components. I'm also pretty sure I've never seen one which included component values. Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |
Many I.C. designs rely on matched devices within their circuitry. Although not impossible, it is tough to do the matching, including temperature gradients across the circuit discretely. You would likely be redesigning the circuit to do it discretely. | |
| | #5 | |
http://www.national.com/ds/LM/LM117.pdf Reverse engineering and chip cloning was pretty common in the cold war when the USSR would reverse engineer US and Japanese ICs in anything from calculators and computer gamse to military computers. No doubt there's still some Russian company who you can pay loads of money to reverse engineer and clone ICs for you.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #6 |
if you know exactly what the IC does and its something not too complicated perhaps you can replicate it with a micro controller ? or find a substitute that will do the same job ?
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! | |
| | #7 | |
er. . .I don't think I'm going to discrete that thing. Even in SMT that would be a bit large. Although it might be fun to do someday just for novelty. Imagine working with someone on a project and pulling out this big box with 3 lugs: "What on Earth is that thing?" "A homebrew 317." s *boggle* ![]() Torben [Edit: hehe. I used 'discrete' as a verb. Calvin: "Verbing weirds language." Sorry all. ]
__________________ Curiosity was framed. Ignorance killed the cat. Last edited by Torben; 17th August 2009 at 06:37 PM. | ||
| | #8 |
| hello,normally things must go and do so but i think you will be oblidged to do an external circuit and make the pins correspond on the main circuit.
| | #9 |
It makes a big difference whether the IC is analog or digital as to generating a discrete clone. Digital circuits would be easier, analog circuits generally much more difficult. But in either case matching the performance of the IC with discrete devices is generally not possible due to the lack of matching and much higher parasitic capacitance of a discrete design layout. Also certain components, like multiple emitter transistors, are not available in discrete devices.
__________________ Carl Curmudgeon Elektroniker | |
| | #10 | |
You wouldn't believe how hard it was to generate a schematic from a 400X plot of surface devices off the die. The plots were as big as a snooker table. Most smart companies never published accurate schematics, they were generalized approximations where circuit sections were lumped together. It was also basically impossible to get a clone of their fabrication process, so the parts worked but not always as well. Last edited by bountyhunter; 17th August 2009 at 10:03 PM. | ||
| | #11 | |
hi Crutschow you 're right enough as Quote:
| | #12 |
| WHat IC do you want to replace? Maybe there is an equivilent that can be subbed.
__________________ Inside every little problem, is a big problem trying to get out. | |
| | #13 |
Well I need CEM3310: Curtis Electromusic Specialties CEM3310 Voltage Controlled Envelope Generator c3310pdf.pdf I was thinking about making more or less PCB that would have similar functionality and properties. I though that there must be some program that would help me to do this. | |
| | #14 |
I suppose it's theoretically possible to re-create it using a mixture of logic gates, matched transistors, op-amps and analogue switches but it won't be cheap or easy. I think your best bet it to find a more modern IC which can do the same job.
| | #15 | |
You best bet is to find a different IC (or perhaps several ICs connected together) to perform the same functions.
__________________ Carl Curmudgeon Elektroniker | ||
| circuit, conversion, discrete, integrated, needed |
| Looking for a TEA5711 DIP integrated circuit | radiomate | Datasheet/Parts Requests | 15 | 8th January 2009 07:34 PM |
| Average Lifespan of Integrated Circuit | PBXTech | General Electronics Chat | 13 | 27th February 2007 02:18 PM |
| Basic Subject About Integrated Circuit Enable Pin :o) | senem | Electronic Projects Design/Ideas/Reviews | 2 | 11th June 2005 01:11 AM |
| project for linear integrated circuit analysis | milobond | General Electronics Chat | 1 | 5th September 2004 04:00 AM |
| Integrated Circuit Boards | ad353 | General Electronics Chat | 1 | 21st January 2004 10:09 PM |
