Here's how I find the break in the cable:
- Make sure nothing is connected to the cable and that it isn't touching an earthed part or large piece of metal casing.
- Warn people that the cable is going to be live.
- Connect the cable to the live mains conductor.
- Use a DVM with a non-contact mains frequency electric field detector to scan the cable. The point in the cable where it stops beeping or becomes less sensitive is where there's a break.
- Disconnect the cable from the mains.
You could also use a neon lamp and a high frequency high voltage source such as a cold cathode tube driver, just make sure the voltage is below 1kV or it could burn through insulation or arc across connecto contacts.
