I've read through the datasheets and I'm ashamed to say I'm stuck. One of the problems is that I can't find two datasheets from the same manufacturer and different manufacturers are going to vary somewhat. I already have loads of CD4009s in my junk box, I'm just wondering if it's worth buying some CD4069s as well.
THey have different power supply schemes and the output circuitry is different. 4009 also has noticeably higher output drive current.
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 13th August 2009 at 11:50 PM. | |
Is the answer 60?
__________________ Mike2545 | |
| Interesting, I thought the higher numbers were supposed to be better? As the output current is higher does that mean I can't use the CD4009 as a linear amplifier? EDIT: I also couldn't find any referance to the gain on either of the datasheets, is there a difference?
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 13th August 2009 at 11:57 PM. | |
The CD4069 parts that are for sale these days always have a U after the number, that is CD4069U and this is important. This indicates that it is an UNBUFFERED gate/inverter, which is different than the CD4009. Here is a link that explains the difference: http://focus.ti.com/lit/an/scha004/scha004.pdf It is possible to buy "U" versions of 4009's and other logic parts as well, but they would be marked as 4009U in that case, and then I don't think there would be much difference with a 4069U in that case. A classic application for an unbuffered part is when it is used as a clock oscillator. In this case the shorter propagation delay through the part, and slightly less complex transfer function means it oscillates at higher frequency and more reliably.
__________________ RadioRon | |
| | #6 |
That app note was a great read! Keep linking good, informative sources.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
| | #7 |
very seldom will you find the gain or the linear portion of the transfer curve mentioned in a CMOS inverter data sheet, just because they're "logic" devices, and the linear portion of the transfer curve is something of an "undocumented feature".
__________________ .................................................. .................................................. . E=mc˛ (+/-1dB) "If a curl of smoke is seen, the technician will soon experience the cause of difficulty"........ CTX arcade game rgb monitor service manual 1985 DC-to-Daylight Blog (on this forum): http://www.electro-tech-online.com/blogs/unclejed613/ | |
| | #8 | |
The ones I have are UBs so maybe I should buy some Bs.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 14th August 2009 at 02:06 PM. | ||
| | #9 |
The CD4009 is not recommended by Texas Instruments. The CD4049 is recommended instead if it has a single supply voltage. Both [/quote] are not symmetrical. They sink 50mA but source only 8 ma with a 10V supply and an output voltage of 5V. If they are used as a linear amplifier then they self-bias at an output voltage too low and with low gain. They also might melt. These and the CD4069 are logic inverters that are always Un-Buffered. The CD4069 has symmetrical source and sink currents but not as high as 50mA. It works well as a linear amplifier. Here is a graph of the gain and frequency response of a CD4069 (or a 74C04) Cmos inverting amplifier:
| | #10 |
Where did you get that graph from? It's not on the datasheet.
| | #11 |
| I got the graph from RCA in the 60's. RCA Semi got bought by Harris. Harris got bought by Intersil. Parts of Intersil got bought by Maxim. I don't know who will buy Maxim.
| | #12 |
It looks like I'll have to order some CD4069s or 74C04s then.
| | #13 |
A Cmos inverter makes a pretty distorted output because its output compesses the signal near the rail voltages.
| | #14 |
That shouldn't be a problem at low gains, due to negative feedback. Not going to near either rail should also help.
| | #15 |
I made some fairly low distortion (0.02%) sinewave oscillators with the inverter from a CD4069 used as a compressing linear amplifier to fix the amplitude. It was fed the signal from a switched-capacitor lowpass filter IC and both were together in a feedback loop. The lowpass filter reduced the 3rd harmonic distortion caused by the compression.
| cd4009, cd4069, difference |
| difference | raviram87 | Robotics Chat | 4 | 10th January 2008 04:47 AM |
| Is there a difference? | hjl4 | Chit-Chat | 6 | 18th September 2007 08:07 PM |
| building infrared TX and RX with CD4069 OR SN74H04 | timothy | Electronic Projects Design/Ideas/Reviews | 1 | 19th March 2005 03:28 AM |
| difference | Capacitor | General Electronics Chat | 1 | 12th January 2004 02:56 PM |
| What is the difference? | zafarjanjua | Micro Controllers | 1 | 22nd August 2003 03:07 PM |
