Old 16th June 2004, 01:52 AM   (permalink)
Default SMD compatability
Are SMD components compatible with regular components? SMD is so small, how do you solder the pieces on?
duffman is offline   Reply With Quote
Old 16th June 2004, 02:05 AM   (permalink)
The way I do it, is to coat the pads with a generous amount of solder and lots of flux. I place the part and reflow the solder with a small iron, altho a larger iron might be able to reflow more than one lead at a time. To remove a SOIC, I lay some desoldering braid along one side and run the iron up and down to heat the whole side while prying gently with an exacto knife..
The secret to solder SO devices is use lots of flux and minimum solder. My eyesight is not what it used to be, so I check each connection with a buzzer.
Russlk is offline   Reply With Quote
Old 16th June 2004, 04:14 PM   (permalink)
So they are compatible?
Old 16th June 2004, 04:21 PM   (permalink)
Considering you can buy the same devices in smd and through hole, I would assume all SMD components are just the same as regular ones, except smaller.
The first rule of mstechca club is do not talk about mstechca club.
http://www.electro-tech-online.com/s...induser&u=1245
2camjohn is offline   Reply With Quote
Old 16th June 2004, 05:38 PM   (permalink)
Like 2camjohn said the silicon inside the package is the same for both surface mount and through hole parts so they can be treated the same.
For SOP packages I just use a fine tip on the soldering iron and go pin by pin. For .5mm pitch pins you can just tack all the pins together with lots of solder to initially attach them to the pads and then use solder braid to remove excess solder. I talked to someone from National Semi who claimed he was able to solder BGAs with a heat gun.
Brent
bmcculla is offline   Reply With Quote
Old 16th June 2004, 05:56 PM   (permalink)
Default SMT
The only compatibility issue I can think of is power dissipation, obviously lower with SMT due to package size. Rarely a problem, but something to be aware of. The hardest thing when manually soldering a SMT part is keeping the package from moving. I use a very low-tech method to hold parts in place, a tiny bit of masking tape placed over half the part. After the open pin(s) are soldered, remove the tape and solder the other half. It works well, just use a new piece of tape every 10 parts or so.
laroche73 is offline   Reply With Quote
