+ Reply to Thread
Results 1 to 5 of 5
Thread: capacitor between power and ground?
  1. #1
    AXmichigan Newbie
    Join Date
    Jun 2009
    Location
    Washington, DC
    Posts
    14
    Default capacitor between power and ground?
    hey guys
    so i just bought these pumps from china for this project i am working on
    i found them initially because i opened a bp cuff and saw them in
    the pumps they sent are just with empty nodes to solder on which is fine
    but i was wondering, because the pumps in the bp cuffs have a capacitor between the power & ground
    why did they do that?
    and what capacitor size should i use, does it matter?
    i ask because the pump worked before, and now is seeming to be shorting my project when connected
    is this part of the problem?
    thanks!
  2. #2
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Are you talking about an AC driven motor?
    If yes, the capacitor is used for phase shift to operate a three phase motor using single phase and neutral.
    Without the cap the motor would hum only and finally burn up.
  3. #3
    AXmichigan Newbie
    Join Date
    Jun 2009
    Location
    Washington, DC
    Posts
    14
    i think it is a dc driven pump?
    Koge design and produce mini diaphgram pump piston pump solenoid valve coin and magnetic solenoid PRESSURE PUMPS?VACUUM PUMPS?WATER PUMP?SOLENOID VALVES?LINEAR VALVE?SOLENOID COILS?MAGNETIC SOLENO
    it was working without the capacitor, and still does
    but when i plug it into the circuit now it developed like a short (voltage went from 5v to 0.1mv)
    any ideas?
  4. #4
    sheldonstv Good sheldonstv Good sheldonstv Good
    Join Date
    Jul 2005
    Location
    warwickshire
    Posts
    207
    check the pumps ratings..........3v dc supply??yr 5v supply may have kiled it
    all "txt speak" has been removed from this post for the benefit of all other forum members who may get confused!!!
  5. #5
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Yes, it is a DC driven pump motor.
    Normally they are fitted with a cap across the motor to reduce back EMF. If that cap is shorted (either caused by "monday production" or any other reason) the power supply will drop to its minimum if it is current limiting, since a shorted cap is a dead short for the power supply.
    A quick check for the capacitor: Connect it to a multimeter using the lowest resistance setting and observe the values indicated on the display. They should start at a low reading (overflow due to short) and increase readout until the cap is fully charged to the voltage source of the multimeter and stay there. Then reverse the probes and observe again. This time the reversely charged cap should indicate a dead short which should disapppear quickly when charge current approaches zero because of reversed charging.
    (Hope you understand the procedure - German English )
    I didn't dig into details about those pumps, but I guess the manufacturer won't use an unnecessary cap for them.
    Replace the cap by one with the same capacitance and you'r e done. Use a voltage rating 8 to 10 times the nominal operating voltage of the pump motor.
    Most decoupling caps are rated 63 or 100VDC, so it's fine to use one of those.
    Boncuk
+ Reply to Thread
  1. purpos of branch with a capacitor leading to ground?
    By Triode in forum General Electronics Chat
    Latest: 24th June 2009, 06:25 PM
  2. What is Chassis Ground, Technical Ground, Circuit Ground?
    By victor in forum General Electronics Chat
    Latest: 11th October 2008, 11:42 AM
  3. Ground/Power Planes
    By Stellarcore in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd November 2007, 08:18 AM
  4. power ground
    By Tortuga0303 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th May 2007, 10:21 PM
  5. ground/power plane
    By arod in forum General Electronics Chat
    Latest: 19th April 2007, 02:51 AM
Tags for this Thread
